PARKE wrote on 2021-07-01, 11:29:There does not seem to have been a universal solution for slotket brackets.
Some models came with full covers, some models came […]
Some models came with full covers, some models came with motherboard brackets plus a latch over the top and some models came with the little clips as in your example photos with the Eagle 30-900sp-000-42A.
The slotket in your pc is a from the Super Slocket III aka Startech PPGA2SLOT1 family.
Startech marketed their slotket like this:
The earlier version of that slotket, marketed as Maxtium CPU370, came with brackets+latch like this:
When you order something be aware that the solutions chosen by various slotket manufacterers did not always fit seamlessly with the brackets that are found on various motherboards.
Thanks! This is some really useful information! I might just ask a friend of mine to help and create a similar 3D model for this bracket that's pictured there.
BitWrangler wrote on 2021-07-01, 12:57:
Yah, they all had slightly different corners for their supplied kludges to fit on. The way to get one universal I think would be to ignore the corners and make one that just engaged the sides of the PCB, without being too deep that it might hit components on some models. You'd just have a slot in it the full height of the slotket, and maybe some thin crush wedges inside the slot so it would fit firmly to the edge of the slotket. Maybe also at the top where the corners indent, have crush vanes across, so when forcing it into there, it squishes back the ones where there's PCB and leaves the ones where there is notch, so it helps stop the slotket slipping up the rails. Personally, I'd probably hot glue them on as well.
edit: Okay the flaw in my cunning plan is that there's limited and variable amounts of space between slotkets and sides of the clamp brackets, meaning probably that the "spine" of the adapter would be too thin and floppy.
Yes. You might be on to something here. The flaw you've mentioned though, is something i've been wrestling with too. The glue is something i'm trying to avoid. Especially hot glue near a CPU. The components in this OEM IBM PC 300GL system aren’t original anymore (it had a Pentium II 233 Klamath in there), so i'd be happy to get it all back in there once i'm done playing with it, or once I get something more interesting to play with.
BitWrangler wrote on 2021-07-01, 13:18:Oh you know what I might try, those binder bar things, plastic slide on spine clip, report binders whatever they are called.. […]
I think those are actually the curved back ones, probably want the flat back ones... so I'd cut a strip off to fit between socket and height of retention clamp arm... cut out any clearances needed for components on the slotket, then at the top, if it's wide enough to engage the hooks, cut back the sides a little way leaving the back/spine of it to hook on. Or if it's narrower and goes between the hooks, maybe I'd make it about 7mm taller, and drill a dowel through it at the height where the hooks engage. So those just clipped on would probably stop it flopping back and forward, but to hold it DOWN, I think I'd need to hotglue them on.
Edit: I also see an expedient unpretty solution, in that one could remove the retention arms off the board, then use the screwholes to loop a zip tie through, then pass that through the holes in the slotket, and tighten it up both sides... would keep it IN if tight, but might allow some flop still.
Those strips are actually a really interesting solution to me. They often have some adhesive on one side already, which makes the goal of a neat solution very much achievable, without looking like a dumpster.
The zip ties really won't cut it anymore. They look horrible! Practical thinking makes everything work in the first place, though. So it's a viable solution for anyone that doesn't have the need for a neat look inside the case.
Thanks for those ideas!
PARKE wrote on 2021-07-01, 16:51:
InjecTioN wrote on 2021-07-01, 07:18:8><CUT
I've got a slotket just like this one (or at least the same shape):
8><CUT
I'd be very grateful if anyone can point me in […]
8><CUT
8><CUT
I'd be very grateful if anyone can point me into the right direction.
Thanks in advance!
Which CPU have you installed in that slotket ?
It currently has a Voodoo 2 8MB, AWE64 Gold, Realtek NIC, ATI All-in-Wonder 128 PCI 16MB, Philips CDRW200 series CD writer (black and gold doesn't quite match, though it is period correct ¯\_(ツ)_/¯), 256MB of PC-133 (set to 66MHz at low latencies), an original HDD (soon to be replaced by a 32GB mSATA to pATA 2.5" thing) and as a CPU Intel Celeron 433 MHz Mendocino PPGA (I'm still looking for a Mendocino 533MHz).
Quite the beast for what it should be marketed for. 😏 😎
BitWrangler wrote on 2021-07-01, 17:45:
I had some bits just come in, a partial retention mech, thought it should have hold downs, just has the sides. The slot in those appears to be 12mm. Now those binder clip bars I mentioned seem to be dimensioned internally (For max thickness they will hold I guess) so you'd probably want a "10mm" one if you were gonna try that.
Also got one single shoulder piece which I think is for a MS6905, but it fits very loose, seems like it would only kinda center the board. Got some mix and match parts in another stash I'll have to get out.
Also I believe there were two editions/revisions of the slot retention mechanism from Intel, so that's probably a wrench in the works too.
Also some very useful information! If you've got some more dimensions, my friend might be able to recreate 3D models (to eventually upload on thingiverse.com).
