First post, by Charleston
- Newbie
Purchased this motherboard on Ebay, claims to be an Opti-895, 802G. Sorry for the blurry picture, it's the best I have until it gets here.
From digging I've so far found two that would closely match.
https://www.angelfire.com/mn2/daveandkay/z/A- … el1442Gv1_2.htm
This board appears to be the same but a newer model, although the location of cache is incorrect and there seems to be a few jumpers missing or in the wrong locations so I don't know if it's useable for settings.
https://stason.org/TULARC/pc/motherboards/Q/Q … B486P3-151.html
This board appears to match almost completely although again there seem to be a few moved jumpers and it's not even an Opti 895, so it makes me think it's just a coincidence.
The other number on the board I've picked out is V4P895P3, but I can't find anything online about it (or I just don't know how to use google anymore).
Considering it has 895 in the middle of that model code I'd have to guess it's probably not the second board I found.
I'd appreciate any help in IDing this! If I can just use one of the two I've found and it being an older model doesn't matter that's ok too.
Thank you!
