Reply 40 of 50, by LSS10999
someitguy wrote on 2024-02-04, 01:09:BTW you can easily slipstream ntfs.sys from NT4 SP6 into nt3.51 ISO. In fact there is an nt 3.51 w SP5 includd ISO that uses the WIn2K bootloader. Use WinISO and swap the ntfs.sys in the i386 folder. 3.51 will happily use the newer NTFS format zero issues.
STOP! DON'T DO THAT.
NT 3.51 lacks many symbols commonly used by NT 4.0 and onwards. The new drivers will not even run.
Try running Dependency Walker from inside NT 3.51 and check the new ntfs.sys with it, and you'll know why.
On the other hand, Win2K bootloader (NTLDR) has nothing to do with the kernel and other stuffs, just that it is the last bootloader version that still has the ability to boot a NT 3.51 install, with improved functionality compared to original NT 3.x/4.x NTLDR. That's why you can use Win2K NTLDR for NT 3.51, but that's it.
