First post, by Deffnator
So, this is something i stumbled out recently
http://zelya.war2.ru/
And its GoG announcement thread.
https://www.gog.com/forum/warcraft_orcs_and_humans/winwar
Its getting regular updates, and it works fine.
Here are its last changes
12.06.2021 version 0.6.9
- Captial explosion fix
- SlimDX for Windows sound
- Timing fixes
5.04.2021 version 0.6.8
- Resources file optimization
- Fixed issue with music not played
- Fixed issue with ending sound
- Refactoring for Mac resources
24.01.2021 version 0.6.7
- AI magic fix
- Check free space fix
23.01.2021 version 0.6.6
- AI rebuild structure fix
- Localization fix
23.01.2021 version 0.6.5
- Dead caster fix
22.01.2021 version 0.6.4
- Fix for action cancel
- Proper score calculation
- Fix for orcs ending movie
20.01.2021 versions 0.6.2, 0.6.3
- Changes for Map Editor
03.12.2020 version 0.6.1
- Building walls fix
- Score screen minor fixes
- Changes in Android audio system
03.11.2020 version 0.6.0
- New sound system
- New video system for Windows
- Fullscreen (alt+Enter) for Windows
- Rest of cheat codes implemented
- Basic implementation for ending video (not finished)
02.11.2020 version 0.5.11
- Ai repair fix
27.10.2020 version 0.5.10
- New sound system
- Double tap selection improvements for Android
- Error logs for Android
26.10.2020 version 0.5.9
- AI barracks logic fix
- Empty message for Android fix
25.10.2020 version 0.5.8
- Wrong object status after recreation fix
24.10.2020 version 0.5.7
- Network connection error fix
- Refactoring for MapEditor
23.10.2020 version 0.5.6
- Fixed wrong flags for dead units
- Fixed game save crash
- Fixed settings saving for Android
23.09.2020 version 0.5.5
- Fixed double tap selection for Android
"sourceport" vs "decompilation"
edit: wow not even that:
"It is completely rewritten from scratch using only the original art and level data."
aqrit wrote on 2021-11-07, 17:26:"sourceport" vs "decompilation"
I treat it as the same since like War1gus it needs the original files to read everything.
in all cases, i hope this project goes forward, War1 needs more love, and if anything a working Windows Port since Blizzard dropped that at the last minute when they released the Retail CD version.
And if anything, use the Redbook audio and the high res assets the mac port has.
I've been following that project's development for a while. It is indeed based on DOS binary decompilation, so it's not "written from scratch" in the same way as engine recreations that are created purely from observation and guesswork. I believe that it is, in fact, so accurate that you can play the original DOS version in network mode against this recreation:
https://www.youtube.com/watch?v=KXWf1ENXMKc&l … uN_19gCzx29FcWx
When the author says "completely rewritten from scratch" it means conversion from ASM to C#.
