I try to find some information about connectors and jumpers for exactly the same card:
I searched for manual - but I can't find anything.
It has a single power connector. Does it have to be connected to work? AT PSU has two power connectors. Which one I should use? And what about powering the rest od the motherboard, if one power connector is in use by this card?
Ok.. after spending waaaayyyy too much time scouring the web, most listings I saw for ones like this say it is an Axiomtek part, but I found one that was exactly the same, except without SCSI that showed a picture of the back.
The part number was NEAT-551 which is an IEI part. Looking on another page lists the similar parts, NEAT-553 looks to be the one with SCSI.
Still can't find a manual for it though. None of the archived IEI sites seem to have any of this model range.
Edit:
Found another pick of a different one, the NEAT-552. It had another sticker on it labeled NEATEK.
Did a web.archive.org search and came up with the NEATEK website.
cyclone3dwrote on 2021-11-23, 03:53:Ok.. after spending waaaayyyy too much time scouring the web, most listings I saw for ones like this say it is an Axiomtek part […] Show full quote
Edit:
First of all, I cannot express how thankful I'm for helping me with that.
My SBC card is exactly the same, like the one above, but it has no SCSI connectors soldered. Not sure if it is a different model, but your linked manual (550) seems to be accurate about all!
In it, I found a power connector diagram
So it looked like P8 power connector from AT PSU.
So I connected it, along with VGA and... it worked!
Looks like MMX, so a little too fast for my project 🙁 I would rather have something like 486DX4-Pentium 166 on it 🙁
I was thinking about getting like 3 slots backbone with such card, and putting it into case like this What did I just bought and how to use it? thread.
I still have to figure out that connector, or just replacing whole display in it, and get backbone for it, but one day I will
