Reply 303 of 600, by Deksor
Yeah but I think all k6-2+ are potential k6-3+ with that mod
My 550mhz k6-2+ has the same number
Reply 304 of 600, by Sphere478
lukas12p wrote on 2022-03-09, 09:19:
Hi
Can You all write this number of successful and unsuccessful moded cpus? Maybe this is the clue?
All of my + cpus say the same number. 500 2+, 550 2+, 550 3+, 570 2+
So far all of the 2+ 570s have unlocked without issue. They are basically giving the same results as a typical 550 3+ With overclocking and everything
Is that your chip in the pic? Have you modded it? If so post results.
Sphere's PCB projects.
Reply 306 of 600, by Sphere478
The concrete polyurethane seems to be a better match for the original stuff than the first urethane stuff I used in the pics.
But the thermal adhesive epoxy seems to be a even better option.
It seems to look pretty good as a final product also. This time around I used it on the core and the corners.
I’ll do some tests with it and see how well it does.
The really nice thing about this stuff is that it seems to set up quickly a matter of minutes, and I imagine mostly full cure is less than a day. Where as the other stuff seems like a week.
When doing this it’s hard to explain just how little you have to use, it’s about as much as a very small rain drop on the corners and about a medium rain drop on the core, but be sure to spread it over the core kinda thin, the point is to smoosh the ihs against the core.
The epoxy starts to set up so quick that I really didn’t stop and try to take pics before putting the ihs on, sorry.
Anyway, I present to you the latest method:
Example of epoxy applied:
Re: SUCCESSFUL K6-2+ to K6-3+ Full Cache Enable Mod
    1.22 MiB
    1.27 MiB
    1.35 MiB
    1.17 MiB
Reply 307 of 600, by Sphere478
Epoxy cpu lives!
Btw, does the k6 have a temp sensor or is this on the mobo? (It doesn’t have a tab type one under the socket)
    1.03 MiB
Reply 308 of 600, by Doornkaat
Sphere478 wrote on 2022-03-12, 08:42:
Epoxy cpu lives!
I don't think the CPU has got a sensor. There must be one in the socket. What board is this?
Reply 309 of 600, by Sphere478
Doornkaat wrote on 2022-03-12, 08:44:
Epoxy cpu lives!
https://www.ultimateretro.net/en/motherboards/10151
Reply 310 of 600, by Doornkaat
Sphere478 wrote on 2022-03-12, 08:56:
Epoxy cpu lives!
R55 could be a thermistor. Can't say for sure though.
Reply 311 of 600, by Sphere478
Doornkaat wrote on 2022-03-12, 09:00:
On my non ultra that IC is a pink cylinder. You may be correct. There is another one located by the rear I/O by pci slots
Reply 313 of 600, by Sphere478
Doornkaat wrote on 2022-03-12, 09:49:
Mistery solved I guess, though it would have been nicer if there was an on-die sensor.🤷‍♂️
I wonder if it could be replaced with a tab type on a foam pad with a little TIM
Reply 314 of 600, by 0xCats
Epoxy cpu lives!
It doesn't have an integrated sensor, hence also no thermal protection.
The thermistor is instead located on the motherboard inside the socket hole, and are as a result woefully inaccurate.
There are two types of devices, those that know they've been hacked and those that don't yet know they're going to be hacked.
Reply 315 of 600, by Doornkaat
Sphere478 wrote on 2022-03-12, 10:32:
I'm pretty sure it could but I have no idea how to figure out the right values.
Reply 316 of 600, by Doornkaat
Thinking about this again, you could put a copper plate with a soft ~1mm thick thermal pad for electrical insulation into the socket so the CPU has more direct contact to the thermistor.
Know what I mean?
Reply 317 of 600, by BitWrangler
The problem adapted to my skillset and available junk would go... get thermal foam pad out of junk CDROM... cut about 1cm off a piece of ~1/4" copper or aluminum pipe.... squish that to slightly under approx distance between CPU and thermistor... thermal epoxy it to CPU above where thermistor is, drop foam pad on thermistor (and if you're paranoid, tape off everywhere a loose copper pipe could short) squish CPU into socket and lock.
Reply 318 of 600, by Doornkaat
BitWrangler wrote on 2022-03-12, 17:04:
He gets it! 👍
Reply 319 of 600, by Sphere478
The smd has exposed contacts. But could work, “bring the temp to the cpu”
Doornkaat wrote on 2022-03-12, 12:37:
I would have to remove the sensor and solder leads to it, and attach several different value resistors or use a POT and make a temperature vs resistance graph noting the resistance the bios displayed it’s either a ptc, ntc the graph will tell. Then I have to find a device that matches the graph I make.
0xCats wrote on 2022-03-12, 11:28:
Epoxy cpu lives!
I thought that was the case, but was wondering if the 2\3+ was a exception. Makes sense that it wouldn’t be since it is the same socket. I have one bobo with a tab sensor. But didn’t see one here.I think you guys are correct about r55 😀
