Reply 60 of 156, by ajacocks
First unit built, and all voltages check out OK!
586.67 KiB
PICO-AT Hi-Current v0.4 back
982.01 KiB
PICO-AT Hi-Current v0.4 front
Thanks wiretap!
- Alex
Reply 62 of 156, by Sphere478
Nice!!
How’s it work on the mobo?
Does it seem like it has too much leverage when moving the cable around? Maybe damaging the mobo? Guessing it’s short enough to not be an issue?
I wonder if we can make it even shorter yet by moving the power switch header to the side and making the atx connector solder to the front and back edge of the board. If atx connectors are hard to find, these could be cut.
Probably not worth messing with though, looks like a great product as is!
Sphere's PCB projects.
Reply 64 of 156, by Sphere478
since the AT connector needs to be swapped anyway on many boards, what about a adapter that solders directly to the board? are there pin headers of the proper size for a right angle mount?
Reply 65 of 156, by imi
I'd worry about the leverage on the solder joints when plugging the ATX in that case, I think a plugged adapter is better in that regard cause you can plug it in afterwards, unless you put the ATX connector on a cable maybe.
Reply 66 of 156, by wiretap
The leverage isn't bad, just train the cable. But, those solder points for the power connector are pretty large. I wouldn't worry about a light cable hanging off it damaging anything.
My Github
Circuit Board Repair Manuals
Reply 67 of 156, by Sphere478
Probably going to order one of these soon, figured I'd take a crack at making it even shorter! 😀
PICO-AT-high-current.zip
962.72 KiB
48 downloads
Hope you don't mind Wiretap. 😀
Double check me here, how's it look?
-I connected the two -5v pins. it shouldn't hurt anything if two -5v supplies are in parallel. and also, if my psu has -5v I can avoid having to install the regulator.
-I also made some adjustments here and there that I think should make it handle even more current.
-Added silk under the fet to protect those masked lines more from the fet tab. Not needed but doesn't hurt.
    111.52 KiB
    82.89 KiB
Reply 69 of 156, by Sphere478
wiretap wrote on 2022-04-29, 10:42:
Looks good. 😀 You can adjust the thermal spoke width in the fill settings to give yourself some more current carrying capacity.
Thanks! I just updated the file again. (small tweaks).
Yeah I made them larger actually, I noticed the power planes were solid, I think it's okay that they are spoked. I see someone above had a little trouble getting the solder to flow. So I set all planes to thermal relief mode. But I did increase the thermal spoke width.
Most applications won't exceed 5a 12v tops and 10A or so maybe 12 on the 5v tops. I base this on my atx2at readings. and that's loaded with cards and ram and dual processor. Someone using this witha pico psu and low power parts is looking at a fair amount less than that.
This of course should work great with a normal psu also.
Reply 70 of 156, by Sphere478
I've never set up a pcb to be manufactured fully assembled. can we do that here? Do you know how? or is it already ready to go?
are there horizontal L pin headers that we can use in place of the male and female AT connectors (direct solder option)? I can't seem to find one.
Edit: Made a order for the pcb! (pcb only)
Reply 71 of 156, by Sphere478
Note: error cap position is reversed.
New version:
1.64 MiB
46 downloads
Those traces passing under the fet bugged me 🤣
Also here is a better view of the layers:
126.99 KiB
149.81 KiB
144.23 KiB
154.31 KiB
Reply 72 of 156, by Sphere478
3d
    112.61 KiB
    79.54 KiB
Reply 73 of 156, by ajacocks
I wonder if it’s worthwhile to implement a PicoPSU replacement on a larger board? It’d be really nice to just be able to plug in DC power and have all the regulators on a single device.
- Alex
Reply 74 of 156, by Sphere478
ajacocks wrote on 2022-05-11, 14:24:
- Alex
It seems like this kinda goes hand in hand with smaller cases also, because if using a ATX case there isn’t much point not to just use a full size psu.
I had a thought though, it may be possible to plug more than one pico psu into a single mobo.
Reply 75 of 156, by Sphere478
If we can find some PNs for male and female vertical connectors we can make a splitter that pluggs into this allowing multiple pico psus
Reply 76 of 156, by Sphere478
Just noticed redundant trace between 5v atx pin and 5v led.
The via already connects it to 5v plane. So trace could be removed 🤔
wiretap wrote on 2022-02-21, 03:09:
Yea, don't buy the Chinese knockoff Pico PSU's. The real PicoPSU can output roughly the same amount of amps on both the 12V and 5V rails. They obviously shouldn't be used in late AT systems, but rather for Pentium MMX and prior AT or SBC systems.
Can you drop a link to the best one to get? I got one but it was wired all weird and won’t even turn on it seems 🤣
Reply 77 of 156, by Jura Tastatura
Just an idea, to make similar adapter in the same format but 24pin atx -> 20pin atx that would also give -5v to mbo from modern atx psu. I'd buy that, been searching for a long time but only seen atx-at adapters...
Reply 78 of 156, by Sphere478
Jura Tastatura wrote on 2022-05-11, 18:22:
Make a thread, find the plugs and kicad footprints and if I get time I’ll try and throw it all together.
Reply 79 of 156, by weedeewee
Its not a PCB but easiest way to do what you need is get a fully wired 24 atx to 20 atx cable and solder in a 7905 and two capacitors, someone made a small pcb for the components and it's here on the forum but I'm too sleepy to find the link to it.
also, I think the title of this thread should be changed to AT pico adapter :-p
Do not ask Why !
