Reply 20 of 30, by debs3759
- Oldbie
marmotta wrote on 2022-04-21, 08:35:Horun wrote on 2022-04-21, 00:18:Can you post a picture of your board? Just because you have a 25Mhz Harris does not mean it is running at 25Mhz (I have a board with 20Mhz Harris in a 16Mhz board)...
This is my board, which card do you have?
I see no other reply that says this - the 32Hz crystal means your 286-25 is actually running at 16 MHz when you get it running again.
