First post, by Baoran
On SY-5EMA+ motherboard and K6-3+ cpu when testing with speedsys things are normal with single 256MB memory stick and speedsys shows 3 levels of cache in the graph but if you add second 256MB stick the reading test stays the same but writing test becomes flat like all 3 levels of cache would be disabled when writing to memory.
I dont really need 2 sticks there but if anyone knows why this happens just for writing and even with the cache that is on the cpu I would like to know.
