First post, by Bendejo
As the title states, I want to make a build that showcases the video card. At first i was thinking maybe going with a Windows98/XP build. But maybe it would be better to go another route?
So for Windows 98/XP i had something like LGA775, Intel Core 2 Duo E8600/ Intel Core 2 Quad Q9650 for highest performance. These I heard can also be down clocked quite low to give better compatibility for speed sensitive games. These CPU should have no problem with anything either OS should throw at it. Though I do understand the video card would be very limited in XP. I seen it struggle with half life 2 so that's about as far as I would probably take it.
But do you think maybe I should take this a different direction? like singular high end 98/3DFX build or even flexible DOS/98/XP?
So much to think about.
