Reply 80 of 147, by Ozzuneoj
- l33t
If I needed a PCI card for a retro gaming PC without spending a ton of money on the rare stuff I would look for these. They are listed roughly in order of how fast the machine would be. For a Pentium 133 I wouldn't bother going any further than a TNT2.
Riva 128, TNT, TNT 2 (M64 or Vanta), Geforce 2 MX (original, 200, 400), Geforce4 MX 4000, Geforce FX 5200, Geforce FX 5500 (basically the same as 5200 most of the time), Geforce 6200
This doesn't affect you much, but you will often find Jaton brand Geforce cards in PCI configurations for much cheaper than other brands because they are a bit hard to tell apart. They usually have "PCI" in the model name.
In a pinch, ATI cards could be used but I don't have as much experience with them. Still, I have found these ones are at least decent. I don't know how they would run on a P133, but I'd guess that anything more than a Rage 128 would be a bad idea.
Rage Pro, Rage 128, Radeon (many variations), Radeon 9250 (neutered specs, but fast enough for some things), Radeon 9100 (basically an 8500LE... very fast PCI card for the time)
As others have mentioned, some other non-3dfx\nvidia\ATi PCI cards could be used in a pinch if you're feeling adventurous, but 3D support may be pretty bad. S3 Savage cards are probably among the better alternatives, but not real common in PCI... in fact I don't know if I have a single one, but I have several AGP variants. Matrox also has some passable options from the late 90s, but again, anything but AGP cards are pretty uncommon from my experience... except maybe the G200? Those are pretty common.
Same goes for all of the basic 3D-capable cards from Trident (eugh!), SiS, 3D Labs Permedia, and others. There may be some PCI options out there, but the vast majority are AGP.
Rendition's Verite cards were great and would be an excellent pairing, but they're about as rare as 3dfx cards these days so aren't going to be any cheaper or easier to find.
That pretty much leaves you looking for a Riva 128 or TNT of some kind if you want good compatibility.
