Reply 20 of 20, by Grzyb
- Oldbie
So I wanted to know what's the performance gain of 16-bit external bus in Turbo XT CPUs: 8088 vs. 8086, V20 vs. V30...
V20 @ 10 MHz results are here
V30 @ 10 MHz results are there - Juko Nest N3 XT system w/NEC V30 Acquisition/Build
Conclusion: 16-bit bus makes it about 50..60% faster.
