First post, by DesktopDynamite
Hello,
I would like to setup 3x sound cards based in the following specs:
Mobo: ASUS P3B-F v1.04 Intel 440BX motherboard Slot 1 [2x ISA slot variant]
CPU: PENTIUM III 500Mhz SL37D
Graphics AGP: MEDION MSI GeFORCE4 TI 4200 128MB DDR SDRAM AGP
Graphics PCI: Voodoo 3 2000 PCI
Soundcard PCI: Yamaha YMF724-V AC-XG
Soundcard ISA: Creative Labs Sound Blaster AWE64 value CT4520.
Case: InWin H500 desktop case
Current OS = Win98SE, but intend to use MS-DOS later on]
Currently both sound card have been installed, and since I like the sounds of the Yamaha I decided to set it as the default, hence had to fiddle with IRQ settings and changed IRQ, DMA etc with those of the Creative 64.
Now, regarding the 3rd sound card I am intending to use the MT-32 but emulated using the WP32 MCCAKE with a raspberry pi [www.serdashop.com/WP32-McCake].
Is there anyone with a lot of similar specs who has some info on how to set these up and running ? Would it be possible to use music from Roland-MT-32, Sound Fx from Creative AWE64 for example ? And if so, should I get some type of KVM switch with audio [3.5 jack] to output SFX and Music through the 1x set of speakers ?
Sorry to bombard you here with these questions. Am still learning and grasping ideas from various posts etc, coming from Amiga computers background here.
    607.17 KiB
    45.08 KiB
    192.37 KiB
    272.87 KiB
    222 KiB
Reply 1 of 2, by FinalJenemba
The main issue I see is it doesn't look like either of those cards has a wavetable header. I know the AWE64 value doesn't, since I have one. The Yamaha im not as familiar with but it doesn't seem to have one either. So you aren't going to have a way to actually hook up the the WP32. You would need to have at least one card that has a wavetable header.
Reply 2 of 2, by DesktopDynamite
FinalJenemba wrote on 2023-03-20, 11:23:
Correct,
I was replied that since I don't have wavetable header, it is better to opt for the MT-32L, which is the external version of the day WP32.
Other suggested options are to wait and preorder the orpheus or the Cm8830 card.
I will consider the previous option though, hence keeping both cards and go for the M32L
