Reply 20 of 30, by LSS10999
the3dfxdude wrote on 2023-05-21, 21:31:Well it's kind of like the ISA slot. They first made it "optional", and things like -5V not needed anymore. One by one the manufacturers decide to pull it out, and change chip sets breaking compatibility (you have no slot, so it doesn't need to work like a full ISA bus). Now about 2020 on, ISA bus signaling is getting removed completely that even integrated legacy stuff is long gone. They deleted that line like about -5V like it never existed in the ATX spec. 16/32-bit is kind of coming to that point, now it will be impossible to support a large portion of the PC's existence. In terms of secure boot being optional, again, that is just a recommendation by Microsoft. All that has to happen is the manufacturers start one by one locking down their products. Even if it is an option, eventually you have no option, and they'll delete that line too, like it never happened. So I probably shouldn't say that Win12 will for sure being the deciding factor, but I'm telling you, many things are starting to line up that the x86 platform is going to soon be radically different. I wonder who will pull the trigger, but it will be very subtle.
I recall reading this very interesting quote on ReactOS forum regarding UEFI-only systems.
Any machine that does not support BIOS (AKA Legacy) booting is no longer truly "IBM PC" compatible and does not deserve to be called a "PC"
They are PCs, but IBM-incompatible PCs, so I call them post-IBM PCs.
This left a strong impression inside me when I first saw it back then. The discussion started in 2014, and now, 9 years later, this has become a reality: PCs are indeed deviating farther and farther away from the original "IBM PC", first by being UEFI-only, and now x86S.
