Reply 20 of 178, by weedeewee
Given the datasheet for the ATT20C490,
has anyone disassembled the bios and checked for the 'Software identification' part of the datasheet ?
meh, nevermind, likely a moot point.
Do not ask Why !
Reply 21 of 178, by feipoa
CoffeeOne wrote on 2023-07-04, 20:39:
Yes, but 1024 x 768 65000 col. should / could work also with a 80MHz RAMDAC. Am I correct?
Yes it works, but only in interlaced mode.
Reply 22 of 178, by feipoa
I suspect the ARK branded PLL won't matter, but I was already putting in an IC order, so I added one of these for $2. I also ordered the ATT20C490-11 for $8 and grabbed two. Maybe the second will come in useful down the road.
Reply 23 of 178, by Dorunkāku
If you like big numbers in synthetic benchmarks you can remove R35 and R36 for a core and memory frequency of 80Mhz.
Removing only R36 gives 65Mhz and removing only R35 gives 70Mhz. 80Mhz worked fine on my card with only the 1MB onboard memory.
My card started artifacting at 89Mhz (crystal swap) so at 80 Mhz there is not much headroom left.
Reply 24 of 178, by Anonymous Coward
Interesting. So the Bali32 and the 2Themax cards were both available with 110MHz RAMDACs? I didn't know that.
Other than the different RAMDACs, have you noticed any other physical differences between your card and the Bali32?
Have you tried using a Bali32 BIOS with Bali32 driver package?
Reply 25 of 178, by CoffeeOne
feipoa wrote on 2023-07-04, 23:53:
OK, but why?
1024x768 256 col and 1024x768 64k col need the same clock rate of the RAMDAC (or not?). So there must be another reason. The 256col mode needs 1MB only, the 64k col mode needs 2 MB. So memory bandwidth too low?
In your posting above there was something with 1MB => 70ns, 2MB => 45ns?
EDIT: I guess I am wrong with this assumption.
I found this for RAMDACs used in Mach64 cards:
http://www.xfree86.org/3.3.6/Mach641.html
So early RAMDACs have a reduced clock rate with more colours.
I datasheet of the Ark RAMDAC which is on the Octec card would be really nice to have.
Reply 26 of 178, by Dorunkāku
mpe wrote on 2022-07-09, 20:23:
I believe the ARK RAMDAC is a clone (rebranded copy) of AT&T 21C498 part.
Re: Ark Logic PCI, an interesting VGA card.
Edit nevermind thats not true.
Reply 27 of 178, by CoffeeOne
Dorunkāku wrote on 2023-07-05, 20:03:
Nice.
So it has a maximum speed of 170MHz?
http://www.mouser.com/catalog/specsheets/tvp3409.pdf
EDIT: Actually that is another RAMDAC on the PCI in the linked thread. On my VLB card, there is an ARK1491 chip.
MORE EDIT:
The Ark1491 might be re-branded AT&T 20C491-11 chip. So a 110MHz RAMDAC, but still the 2 modes where 2MB are needed (1024x768 65000c and 1280x1024 256c) are interlaced only.
Reply 28 of 178, by feipoa
@ Dorunkāku
Interesting. I might try this. Was there any speed difference in DOOM or any other games? What memory speed were you running? I've since socketed my DRAM and PLL as shown:
@ AC
I have not noticed any physical differences between the 2themax and Bali32 cards. I have the Bali BIOS and will test the Bali BIOS once I get the 110 MHz RAMDAC.
@ CoffeeOne
I have since replaced the DIP DRAM with 50 ns, but left the SOJ as 60 ns. Anyone have a part number for 50 ns SOJ DRAM that is FPM only (not EDO)?
CoffeeOne wrote on 2023-07-05, 20:13:
It would not surprise me if the ARK1491 is a re-branded ATT20C491-11. The guy I obtained the 2themax card from had compared both the Bali32 w/80 MHz Winbond RAMDAC and the 2themax with ARK1491 and noted that the 2themax demonstrated marginally better output quality. If not for the comment in the 2themax manual stating that non-interlaced 1280x1024x256c is possible with the 110 MHz RAMDAC, I wouldn't be pursuing this. I hope it is not an error of the employee tasked with writing the manual.
1.21 MiB
Reply 29 of 178, by snufkin
Does refresh rate come in to it as well? 1280*1024 is 1.3M pixels. Allow a factor of say 1.4 for blank times for horizontal and vertical flyback, so 1.8M. I think that with a clock of 110MHz that gives around 60Hz max, without any worries about colour depth and memory data rates? And maybe high contrast areas would start looking a bit soft if the DAC struggles to swing the outputs fast enough.
Reply 30 of 178, by mkarcher
feipoa wrote on 2023-07-05, 21:24:
That's not an error. That's in your BIOS. I reversed a lot of it, and I wrote a preliminary register specification in VGADOC style. After an EDIT: Updated with further knowledge obtained from looking at the XFree86 3.3.6 source code.
ARK1000VL  32-bit memory interface; 8-bit DAC interface; VL bus
ARK1000PV 32-bit memory interface; 8-bit DAC interface; VL/PCI
ARK2000PV 64-bit memory interface; 16-bit DAC interface; VL/PCI
3c4h index 10h (R/W): SEQ: feature enable bits
bit 0-5 misc feature enable bits, e.g. accelerator, VESA memory addressing,
linear aperture. In SVGA mode, enable 64K aperture at A0000 if no
LFB is required.
6-7 0: 1MB; 1: 2MB; 2: 4MB (ARK2000 only); 3: reserved
3c4h index 11h (R/W): SEQ: Extended output register
bit 0-1 Giant Shift Register mode (0 = VGA-compatible; 1 = 16-color SVGA;
2 = 256+ color SVGA)
2-3 Accelerator bit depth (0 = 16 colors; 1 = 256 colors;
2 = 64K colors; 3 = 16M colors (ARK2000))
6-7 Bits 2,3 of clock index
3c4h index 12h (R/W): SEQ:
bit 0-1 Aperture size (0 = 64K, 1 = 1M, 2 = 2M, 3 = 4M (ARK2000 only))
3c4h index 13h (R/W): SEQ: LFB base low
bit 0-7 Address bits A16-A23 of linear window
3c4h index 14h (R/W): SEQ: LFB base high
bit 0-7 Address bits A24-A31 of linear window
3c4h index 15h (R/W): SEQ: Write bank
bit 0-5 bank for writing (in 64K units)
3c4h index 16h (R/W): SEQ: Read bank
bit 0-5 bank for reading (in 64K units)
3c4h index 17h (R/W): SEQ:
bit 0-2 accelerator framebuffer width in pixels (0 = 640; 1 = 800; 2 = 1024;
4 = 1280; 5 = 1600; 6 = 2048) [Maybe 3 = 1152?)]
this is only used in "X-Y mode" of the accelerator
3c4h index 18h (R/W): SEQ: FIFO control
bit 0-2 FIFO refill threshold (if there are at least this much free words,
request DRAM access to refill display fifo). ARK2000: measured in
units of 2 words
3 Enable 8-level FIFO if set (? if clear)
4 Enable 16-level FIFO if set (ARK2000 only)
5 FIFO refill threshold bit 3 (extends bit 0-2) (ARK2000 only)
7 FIFO refill threshold bit -1 (extends bit 0-2 to the low end)
(ARK2000 only)
3c4h index 19h (R/W): strapping bits
bit 0 DAC type: 0=110MHz, 1=80MHz
7 bus type: 1=VL, 0=PCI (not on ARK1000VL)
3c4h index 1Ah (R/W): SEQ BIOS flags 1
bit 0 bit 1 of refresh rate for 800x600x32K/64K
1 refresh rate for 800x600x16M
2 bit 1 of refresh rate for 640x480x256
3 bit 1 of refresh rate for 640x480x32K/64K
3c4h index 1Bh (R/W): SEQ BIOS flags 2
bit 0 bit 0 of refresh rate for 640x480x256
1-2 refresh rate for 800x600x16/256
Show last 118 lines
    3-4           refresh rate for 1024x768x16/256
5 refresh rate for 1280x1024x16/256
6 bit 0 of refresh rate for 640x480x32K/64K
7 bit 0 of refresh rate for 800x600x32K/64K
3c4h index 1Ch (R/W): SEQ: DPMS control register
bit 0-1 Power mode: 0=On, 1=Standby, 2=Suspend, 3=Off
2 Activate low-power mode (blank display?)
7 GPO bit, used as RS2 for ICS5342
3c4h index 1Dh (R/W): SEQ: Feature control
bit 0 Unlock extended registers
3c4h index 1Eh (R/W): SEQ BIOS flags 3 (ARK2000 only?)
bit 0-7 scratch register
3c4h index 1Fh (R/W): SEQ BIOS flags 4 (ARK2000 only?)
3c4h index 20h (R/W): SEQ Cursor control
bit 0-1 color depth: 0 = 256 colors, 1 = 16bpp, 2 = 24bpp
2 cursor size: 0 = 32x32; 1 = 64x64
3 show cursor
4 cursor type: 0 = Windows; 1 = X11
3c4h index 21h (R/W): SEQ Cursor X high
bit 0-? bits 8-? of cursor X coordinate
3c4h index 22h (R/W): SEQ Cursor X low
bit 0-7 bits 0-7 of cursor X coordinate
3c4h index 23h (R/W): SEQ Cursor Y high
bit 0-? bits 8-? of cursor Y coordinate
3c4h index 24h (R/W): SEQ Cursor Y low
bit 0-7 bits 0-7 of cursor Y coordinate
3c4h index 25h (R/W): SEQ Cursor memory address
bit 0-5 cursor base (in units of 256 bytes, starting at vmemsize - 16K)
3c4h index 26h (R/W): SEQ Cursor foreground color 1
bit 0-7 cursor foreground color (palette index, or low byte (with blue) of direct color value)
3c4h index 27h (R/W): SEQ Cursor foreground color 2
bit 0-7 cursor foreground color, second byte (high byte in 16bpp, green in 24bpp)
3c4h index 28h (R/W): SEQ Cursor foreground color 3 (ARK2000 only?)
bit 0-7 cursor foreground color, third byte (red in 24bpp)
3c4h index 29h (R/W): SEQ Cursor background color 1
bit 0-7 cursor background color (palette index, or low byte (with blue) of direct color value)
3c4h index 2Ah (R/W): SEQ Cursor bcakground color 2
bit 0-7 cursor background color, second byte (high byte in 16bpp, green in 24bpp)
3c4h index 2Bh (R/W): SEQ Cursor background color 3 (ARK2000 only?)
bit 0-7 cursor background color, third byte (red in 24bpp)
3c4h index 2Ch (R/W): SEQ Cursor X offset
bit 0-? cursor X origin (start pixel inside cursor bitmap)
3c4h index 2Dh (R/W): SEQ Cursor Y offset
bit 0-? cursor Y origin (start row inside cursor bitmap)
3d4h index 40h (R/W): CRTC: Extended overflow register 1
bit 4 Bit 10 of Vertical retrace start (3d4h index 10h)
5 Bit 10 of Vertical blank start (3d4h index 15h)
6 Bit 10 of Vertical displayed (3d4h index 12h)
7 Bit 10 of Vertical total (3d4h index 6)
3d4h index 41h (R/W): CRTC: Extended overflow register 2
bit 0-2 Bits 16-18 of start address (3d4h index 0Ch, 0Dh)
4 Bit 8 of Horizontal retrace start (3d4h index 4)
5 Bit 8 of Horizontal blank start (3d4h index 2)
6 Bit 8 of Horizontal display end (3d4h index 1)
7 Bit 8 of Horizontal total (3d4h index 0)
3d4h index 41h (R/W): CRTC: Extended overflow register 3
bit 3 Bit 8 of Offset (3d4h index 13h)
3d4h index 32h (R/W): CRTC: Interlaced mode vertical retrace offset
bit 0-7 Horizontal total for last scan line of an interlaced frame
3d4h index 44h (R/W): CRTC:
bit 2 Enable interlaced mode
4-5 Extended character clock modes?
3d4h index 46h (R/W): CRTC: (ARK2000 only)
bit 2 Selects 16-bit DAC pixel path if set
3d4h index 50h (R): CRTC: Chip ID
bit 0-2 Chip revision
3-7 Chip type (?? = ARK1000VL; 12 = ARK1000PV; 13 = ARK2000PV;
14 = ARK2000MT; 15 = ATK2000ML)
Video Modes:
VESA:
24h 109h T 132 25 16
26h 10Ah T 132 43 16
27h 10Bh T 132 50 16
31h 102h G 800 600 16 PL4 (also 6Ah)
32h 104h G 1024 768 16 PL4
33h 106h G 1280 1024 16 PL4
40h 101h G 640 480 256 P8
41h 103h G 800 600 256 P8 (also 47h)
42h 105h G 1024 768 256 P8
43h 107h G 1280 1024 256 P8
44h G 1600 1200 256 P8 (requires 110MHz DAC, limited support by VESA extensions)
4Fh 100h G 640 400 256 P8
50h 110h G 640 480 32K P15
51h 113h G 800 600 32K P15
52h 116h G 1024 768 32K P15
54h 111h G 640 480 64K P16
55h 114h G 800 600 64K P16
56h 117h G 1024 768 64K P16
58h 112h G 640 480 16M P24
59h 115h G 800 600 16M P24 (requires 110MHz DAC)
The presence of a 110MHz DAC is detected by the BIOS by reading 3C4 index 19h, bit 0. I can not find any writes to that register in the BIOS code, which would indicate that this register is possibly read-only, and might be initialized from some pull-up, pull-down or 0-ohm strapping resistors on the board. Having a 110MHz DAC unlocks two video modes and a second timing variant on the 1280x1024x16 and 1280x1024x256 mode.
Reply 31 of 178, by mkarcher
You might try whether the DAC type bit is writeable by running this code in DEBUG:
-a100
0100 mov dx,3c4
0103 mov al,19
0105 out dx,al
0106 inc dx
0107 in al,dx
0108 and al,FE
010A out dx,al
010B int 3
010C
-g
(...some register dump)
-q
First edit: fixed logic (need to set to 0, not to set to 1)
Second edit: fixed DEBUG assembly syntax
Reply 32 of 178, by feipoa
@mkarcher
Very impressive; thank you for this code deconstruction.
I didn't see any mention of 1024x768x64k. Do you know if this mode works in non-interlaced mode at 60 Hz w/110 MHz RAMDAC, or if just 1280x1024x256c works in non-interlaced mode w/110 MHz RAMDAC?
If the RAMDAC does not self-identify its speed through some internal register or setting, and we are unable to determine which 0-ohm resistor on the PCB sets 110 MHz, is it possible to hard-code the 110 MHz setting in the BIOS?
I will look into the DEBUG code late this evening, if I'm not too tired (I'm doing a paverstone project around my house right now).
Reply 33 of 178, by mkarcher
feipoa wrote on 2023-07-05, 22:53:
There is just a single timing for 1024x768x32k/64k in the BIOS, so I guess that one is the interlaced timing. This mode is not affected by the 110MHz flag.
That one will be easy: At offset 4391h in the BIOS, there is the byte 74h which is the opcode a conditional jump instruction that is supposed to skip the limiting code if an 110MHz DAC is installed. You can replace it by EBh, to skip the limiting in any case. This will increase the sum of all BIOS bytes by (EBh - 74h) = 77h. To compensate, you have to decrease the checksum byte at offset 7fffh by the same amount, so it becomes D8h - 77h = 61h.
Be aware that this will make the BIOS obey the "1280x1024 noninterlaced" setting. You still need to configure the mode to run non-interlaced, though. If your configuration tool also checks the RAMDAC type bit, it will not allow you to configure that timing.
Please look at the DEBUG post again, if you already typed down the commands. I got the logic wrong. The old code (before edit) will try to configure 80MHz, not 110MHz!
Reply 34 of 178, by mkarcher
I looked into the mode parameters in the BIOS. It seems the parameters for the 1280x1024 interlaced mode are wrong, and run at 120MHz pixel clock instead of 80MHz pixel clock. This will result in a refresh rate of 130Hz (interlaced) instead of 87Hz (interlaced). It's not surprising that you get issues syncing to that signal with any kind of LCD. Furthermore, in 800x600x64K at 70Hz as well as 1024x768x64K at 87i Hz the 80MHz RAMDAC is overclocked at a byte rate of 94.5MB/s, resulting in a pixel rate of 47.7MHz. The datasheet is quite clear that the 80MHz RAMDAC is limited to 80MB/s at any kind of color depth on the ARK1000. The AT&T DAC supports a 16bit double-data-rate transfer mode, but the ARK BIOS doesn't enable it - likely because the ARK1000 chip doesn't support it. In the DDR mode, you may run at up to 66.6MHz pixel clock, i.e. 133.3MB/s.
With the 110MHz RAMDAC, the 800x600x16M mode is available at 56Hz (110MB/s) or 60Hz (120MB/s, again overclocking the DAC).
Reply 35 of 178, by feipoa
That is unfortunate news concerning the 1024x768x64K mode having only one option, namely interlaced. Maybe the Bali32 VGA BIOS tries to force non-interlaced mode? I've attached it here.
Paradise_Bali32_ARKVL1000_BIOS.zip
16.3 KiB
36 downloads
I ran the DEBUG commands, but received an error:
108.96 KiB
When I was installing the drivers in Windows 95, I noticed that there were two options listed:
ARK Logic 32-bit VL
ARK Logic 64-bit VL
50.68 KiB
I've been using the 32-bit VL option. Wasn't only the ARK2000 series 64-bit? Did some manufacturers use the ARK2000PV on a VLB card? Otherwise, why is there a 64-bit VL option listed?
Reply 36 of 178, by WJG6260
feipoa wrote on 2023-07-06, 13:10:
When I was installing the drivers in Windows 95, I noticed that there were two options listed: ARK Logic 32-bit VL ARK Logic 64- […]
ARK Logic 32-bit VL
ARK Logic 64-bit VL
There is an ARK2000PV on a VLB card, as far as I know. I believe AnonymousCoward informed me that this card was only sold via mail order and it’s unknown how many are out there. I presume not too many exist.
The 64-bit option would make sense for the ARK2000PV. As far as I understand, the ARK1000PV and ARK2000PV share VGA cores (mostly) and their main differences come from the Windows GUI acceleration side. The ARK2000PV is a 64-bit accelerator, as you mentioned.
I am somewhat curious if the ARK1000VL supports VLB 2.0. Technically, the Cirrus Logic GD5430 and GD5434 are VLB 2.0-capable. That implies 64-bit transfers might have been implemented on those cards, which VLB 2.0 can do. It would be interesting to determine if the ARK1000VL is a VLB 2.0 device and whether it can handle 64-bit transfers.
I doubt this would mean much in terms of performance, but it would be interesting, nonetheless. The Chips & Technologies F4041 and OPTi 895(A) (and I guess, by extension, the OPTi 802?) are explicitly VLB 2.0-capable chipsets, and the VLB 2.0 standard specifically allows for 64-bit burst reads and writes using two additional pins, B-41 and A-56, which are LBS64# and ACK64#, respectively. I am highly skeptical of this explanation as relates to the ARK drivers. I suspect you are correct and it is the first—insofar as we’re talking about a 64-bit accelerator in the guise of the ARK2000PV. I also have to say that I find it odd/lazy that the drivers would be shared amongst the two cards, with one being 32-bit and one being 64-bit, but I guess if they’re similar enough in design otherwise, it’s not too much of a stretch.
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 37 of 178, by weedeewee
The error being the 'h'. do not type that 'h' .
and the 0, also leave that one out.
Do not ask Why !
Reply 38 of 178, by feipoa
If we are able to obtain the VGA BIOS image for this phantom card, could we just desolder the ARK1000VL and replace it with an ARK2000PV? Or perhaps we could use the BIOS from the ARK2000PV PCI donor card?
Here's the update DEBUG result:
105.53 KiB
Reply 39 of 178, by Dorunkāku
Overclocking from 55Mhz to 80Mhz showed no performance gain at all in 3DBENCH2.
Have a look at the Block diagram in these:
    ark1000pv.pdf
    86.34 KiB
    57 downloads
    ark2000pv.pdf
    81.97 KiB
    55 downloads
