Reply 782 of 1618, by sharangad
RaVeN-05 wrote on 2024-03-19, 11:58:
Can't understand what to do.
Need detailed instruction.
Into the formula 1 folder:
Copy Redline.dll and Verite.dll from the F1 drivers.
Copy V10003D.uc into the system folder.
Try running F1. I think it'll work.
If that doesn't work, what @AgentoftheBSOD did was replace verite.vxd in system with the version from the F1 drivers. I wouldn't advise you to do this because
verite.vxd is part of the installed driver.
@AgentofhteBSOD could get away with replacing verite.vxd because he has proprietary drivers (Canopus Total 3D) which don't come with a Verite.vxd. The vxd file has a different name. I don't even know if you can replace it with reference drivers because verite.vxd should be locked on most systems.
https://www.youtube.com/@sharangadayananda
Reply 785 of 1618, by RaVeN-05
ok i found potential way:
F1 CD has directory RREDLINE by copying all content into F1 directory game starts, 3d scenes of race not works, everything else works , including credit parts.
i think this can be earliest v1000 drivers , and seeing winspd3d.uc makes me think its Speedy3D ported to Windows
in theory F1 should work on v2000 as dos speedy3d works also with glitches, i think it should work also with glitches , and as i see it has main glitch - unability to render Race itself
WARNING !!!!!!!!!!!!!!!!!!!!!!!
this derictory contains *.NMS symbol debug files , and at end there is huge dump of source code~!!!!!!
Thanks Robertmo3 for pointing that =) ~!
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 786 of 1618, by sharangad
Holy...!
What's an nms file?
Can you extract the it?
I think the 3d will work if you copy v10003d.Uc to the system folder.
Reply 787 of 1618, by RaVeN-05
tried to copy to windows\system this file , does nothing
they are easy readable as Text files, scroll down each file and there is sources of each
🤣 "THIS IS UNPUBLISHED PROPRIETARY SOURCE CODE OF RENDITION, INC. "
    rredline.zip
    390.94 KiB
    23 downloads
Reply 788 of 1618, by sharangad
Woohoo! Will check it out later tonight.
ROFLMAO!
Reply 789 of 1618, by sharangad
BTW, figured out what ICR2 in fifo mode does. It literally issues the same commands as rredline, but directly through port and mem writes.
I don't know how fast I can make it go. Tomorrow I'm going to start the rendering block, converting port writes and appending them to command buffers.
Reply 791 of 1618, by BEEN_Nath_58
sharangad wrote on 2024-03-19, 13:29:
The source was right there for more than 25 years.
This message is going to make rounds in the PC emulation sections probably
Reply 793 of 1618, by sharangad
Thank you @robertmo, @agentofthebsod and @raven-05.
You've improved the quality of my life immeasurably!
Reply 796 of 1618, by BEEN_Nath_58
There was a problem mentioned with the V1K driver for the F1 game, check description
https://youtu.be/KVmBDoU1NfA?si=geQmy1jBKQKC61wu
Reply 798 of 1618, by sharangad
VL_PointSurface doesn't recreate the vsurf structure in the source. Vquake2 doesn't survive that with rready. Vhexen2 does. Maybe there's a way to get the golems working.
Reply 799 of 1618, by RaVeN-05
https://github.com/sarah-walker-pcem/veritas? … =readme-ov-file
Disassembler for Rendition Verite V1000/V2000 RISC processor.
