Windows 11 has been released
Reply 80 of 252, by matze79
Windows 11 has 10 years of "beta testing" ahead of it, so who knows what they'll break within this time period.
Well printers still have problems with Windows 10.
Will they work fine on Windows 11 ?
Co2 - for a endless Summer
Reply 81 of 252, by Anders-
matze79 wrote on 2021-10-06, 22:05:
i never said KDE looks like OSX
Windows 11 looks like KDE has mated with OSX
Microsoft has no own Ideas and just adapts Styles of other UIs.
It doesn't really matter who copies who, the important part is whether the (graphical) user interface works.
With windows (also true for some other systems) one is stuck with a "one size fits all" gui, that's the biggest drawback in my opinion.
Måttfull och balanserad.
Reply 82 of 252, by Jo22
chinny22 wrote on 2021-10-06, 11:09:
Best thing about Windows 11? Companies are already retiring "non complaint hardware"
hardware for Late/Overkill XP builds are about to become cheaper 😀
That makes me wonder: Does Win 11 still support booting via BIOS/MBR?
I know of a few friends that run Win 10 x64 on dated PCs from the mid/late 2000s.
But if Win XI doesn't support that anymore (unless hacked to work with Win 10 loader),
then that alone would be a nogo for old PCs, even if they met the new requirements (TPM2, certain CPU instructions).
And considering that UEFI boot became common in the early-mid 2010s,
then the new strict hardware requirements aren't that strict, anyway.
Currently, supported PC hardware that's said to be Win 11 compatible
can be 5 years "old", at best.
So we're at 2017/2016, which is close to the ~ 2011-2015 years in which the first PCs with UEFI (64-Bit UEFI, full implementation) came out.
Reply 83 of 252, by DosFreak
OS works fine with MBR and no UEFI, installer does not.
I'm not aware of any loaders needed. What has been out there is either deleting a .dll, switching out install.wim and also a register key that even Microsoft has published.
https://support.microsoft.com/en-us/windows/w … 8b-2ce77ac7c70e
The script automates the process so you don't have to worry about the above.
Currently running on my motherboard from 2007 x38-DQ6 and processor from 2008 C2Q
Posting again for the robertmo bot Re: Windows 11 has been released
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 84 of 252, by KainXVIII
The Serpent Rider wrote on 2021-10-06, 17:02:
*sad growl* […]
robertmo wrote:
what ever it is i don't have it installed
*sad growl*
ZellSF wrote:
Windows 11 will probably be the same as Windows 10 in terms of compatibility with old games.
Yeah, Win10 has different compatibility even between different builds (usually later builds break some games, like FF8 Remaster)
Reply 86 of 252, by Jo22
Good points so far. 🙂👍
On the other hand, isn't TPM which the new Windows wants, err.., unwelcome in certain places, among other things too? 😉
I wonder how this will have an impact to the acceptance of the new Windows.
For comparison : Back in the 90s, the Microsoft Internet Explorer 5 wasn't allow to provide high encryption strength in places/countries outside the USA.
Thus, here in Europe, it merely had 40 bit encryption strength or so.
Reply 87 of 252, by Anders-
Jo22 wrote on 2021-10-07, 11:31:
Good points so far. 🙂👍 https://c.tenor.com/D1w1eq2--JIAAAAd/winnie-the-pooh-cute.gif On the other hand, isn't TPM which the new […]
Fortunately, the laws has been relaxed a bit since then (afaik) and now "mostly" applies to what they refer to as rogue states.
Reply 88 of 252, by imi
haha, good one! ^^
what didn't work in windows 10 definitely won't work in windows 11 either, the question is how many things that did work in windows 10 won't work in windows 11 😉
Reply 89 of 252, by cyclone3d
MS has revealed a simple registry key that will allow computers running Windows 10 to upgrade to Windows 11 even if the TPM 2.0 or CPU requirements are not met. Still supposedly have to have at least TPM 1.2 but that goes back a lot further.
HKEY_LOCAL_MACHINE\SYSTEM\Setup\MoSetup and then right-click the main panel and create a new DWORD (32-bit) Value with a name of AllowUpgradesWithUnsupportedTPMOrCPU and set its value to 1.
https://www.pcgamer.com/microsoft-reveals-how … for-windows-11/
Yamaha YMF7x4 Guide
Reply 90 of 252, by ZellSF
Printers have never, and will never work fine.
KainXVIII wrote on 2021-10-07, 08:34:
Can't find any reference to that on PCGW so not sure if that's even true? But yes, there will definitely be minor compatibility issues. Changing anything will always break something, even when it makes no sense.
There hasn't to my knowledge been any major compatibility differences between all Windows 8 & 10 versions though.
Reply 91 of 252, by xcomcmdr
I had Dune 2000 that stopped working without Windows 9X Compatibility mode after the Creators' Update. Before, only Admin mode was required (that, and ddrawCompat).
(I really need to use the fan patch for that game anyway, instead).
But that's the only problem that I recall. Overall, since Windows 8 added the 8 BPP compat option, Windows is better than Windows 7 for old games, in my experience.
Reply 92 of 252, by dr_st
imi wrote on 2021-10-07, 12:29:
You know, they say that Android Apps might. Just might! 😀
16-bit programs for start, as there is no longer a 32-bit build. 😁
Reply 93 of 252, by Akuma
Anders- wrote on 2021-10-06, 14:08:
Akuma wrote on 2021-10-06, 13:41:
Its time again for that reminder: The Win10 Privacy Tradeoff: https://www.grc.com/sn/sn-519.htm Steve: I don't know what MSN Foo […]
Steve: I don't know what MSN Food & Drink is, and why it needs to look at me or have the camera on.
Do you think anything changed with the new version?
Nah, MS is still doing their best to battle privacy and integrity. Fortunately there's other operating systems out there.
Totally agree, never looked back either, you?
ZellSF wrote on 2021-10-06, 16:06:
I stopped reading as soon as I saw the privacy concerned person was using Windows 7, and was considering to switch to macOS.
I would consider Windows 11 equally a privacy nightmare as any internet connected, closed source OS .
Why would you read a podcast? MP3 is at the top 😉
Open source is better, but some like Ubuntu have their own privacy problems.
robertmo wrote on 2021-10-06, 14:34:
it need's to know what you eat and drink to offer you food, drinks, leisure, bikes, etc :) the more they know the more they can […]
it need's to know what you eat and drink to offer you food, drinks, leisure, bikes, etc 😀
the more they know the more they can help you
just like we when helping others have to know their pc specs, etc 😀
That is how its sold to you , there is a darker side to this.
Reply 94 of 252, by Jo22
dr_st wrote on 2021-10-07, 19:17:
That's right, I think. And unsigned 32-Bit drivers, I assume.
Gratefully, we have DOSBox which can run Windows 3.1x. 👍
Compatibility of those is much much better to what the old NTVDM had to offer in the past years.
NTVDM was rather decaying after Windows 7, IMHO.
Another alternative nowadays is OTVDM/WineVDM.
It has its shortcomings (no DOS programs, no TWAIN driver support), but at least make Windows 3.x programs run seamlessly on Windows 64-Bit.
Reply 95 of 252, by KainXVIII
ZellSF wrote on 2021-10-07, 17:17:
Printers have never, and will never work fine. […]
Maybe only games from Square-Enix affected 🤣, i don't know
https://steamcommunity.com/games/1026680/anno … 087930337826069
https://steamcommunity.com/games/340170/annou … 435234185445277
https://steamcommunity.com/app/345350/discuss … 27444657016294/ (and then it was fixed)
Reply 99 of 252, by robertmo
DosFreak wrote on 2021-10-05, 16:47:
https://www.reddit.com/r/Windows11/comments/o … s_1_windows_11/
This was back in July with an Insider build.
Anyone have a P4 handy to test?
that one is 65nm and released after first intel core which was also 65nm
it works on a 65nm Phenom 9550
sandbox and guard both selectable
