My Pentium III build
Reply 20 of 46, by khyypio
RoyBatty wrote:
It's well put together. My only advice is to relax.
Your English is clear enough for me to understand fine and I speak it natively.
Looking forward to more.
Thanks! Yes, my on-screen presence is very tense because of my inexperience. Surely my appearance will become more relaxed and natural over time.
Reply 21 of 46, by khyypio
I upgraded my retro-PC:
- Pentium 3 800EB > Pentium 3 1.4 GHz-S Tualatin
- nVidia GeForce 2 GTS > nVidia GeForce 2 Ultra
- SB Live! CT4830 > SB Live! SB0100
- Improved cable management
- Better paintjob
1.73 MiB
1.87 MiB
1.16 MiB
I´m also working on a video about the project 😀
Reply 22 of 46, by texterted
Looks really good, with nice attention to detail.
Looking forwards to the video.
Cheers
Ted
98se:- Asus A8v Dlx. A-64 3000+, 512 mb ddr, Radeon 9800 Pro , SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Windows Home Server v1 :- Gigabyte GA-EP43, Pentium E5200, Bunch of SATA HDD's.
Reply 23 of 46, by jheronimus
Your first video is really impressive!
The picture is great, and you yourself are a nice-looking guy! You also have this sort of dead pan delivery of jokes that works really nice for you.
What kind of equipment do you use for recording? I want to make videos myself, but always figured that I need to get better light in my house.
My Telegram blog about retro hardware (in Russian)
Pentium 133, 32 MB RAM, S3 Trio64V+, Crystal 4232, Dreamblaster X2 and Roland MT-32
Pentium III 1000, 512 MB RAM, Voodoo 5 5500 AGP, SB Live 5.1, SB32 CT3930, Gravis Ultrasound Max rev2.1
Reply 24 of 46, by khyypio
jheronimus wrote on 2019-12-28, 17:21:
Well, thanks! 😁 Photography has been my addiction for almost 8 years now, so I was able to implement my gear and experience into making videos. I have Canon 6D Mark II, Tamron SP 24-70mm F/2.8 Di VC USD and Sigma APO 70-200mm F2.8 EX DG OS HSM readily to be used in video making. I just had get a wireless mic (Saramonic SR-WM4C) and a light. For the light solution I bought an Walimex Spiral Daylight Lamp (50W, E27), which I managed to mod into a speedlight softbox.
Reply 26 of 46, by PCBONEZ
Very nice work.
Your English is fine.
Reply 27 of 46, by khyypio
One of my desires, regarding retro gaming, is getting modern controllers to work on Windows 98 system, specifically wireless controllers. And there´s been a development: https://youtu.be/lNddWqHl5WM
Yes, I finally got first hand confirmation that wireless Dualshock 4s WORKS on Windows 98! However, there are some problems that I need a little help with but before I dive into it, I´d also like to show this:
1.41 MiB
Those are USB-wired Spartan Gear Oplon controllers, they are very cheap and you can choose whether you wan´t to use DirectInput or XInput, DirectInput obviously being the preferred choice. And yes, you can use two of those bad boys at once if you wan´t to play with a friend! You need a USB 2.0 PCI adapter, nusb36.exe driver file and you Windows 98 installation CD. When you´ve installed your adapter and USB drivers, just plug your first gamedpad on your PC and install drivers from your Win98 CD. After this, plug your second gamepad in and repeat.
I can confirm that this particular controller doesn´t require any other drivers, but this isn´t the case with all gamepads. Some controllers need their own drivers and those typically won´t work with Windows 98. So don´t buy the first DI controller you find, make sure it doesn´t need its own drivers!
Now, I bought this
1.33 MiB
from a certain Nordic online shop because according to the description in both the website and the product, it´s suppose work on Windows 98. It doesn´t. The installer in the driver disc won´t finish and give´s this notification:
743.02 KiB
I also can´t find suitable drivers from the internet. So if you´re thinking about buying this dongle for your Win98 rig, DON´T!
Then I tested a Billionton UBTBR2 dongle, a very old Bluetooth 1.2 stick. It will detect and sometimes even pair with DS4 but it simply works unreliably and doesn´t connect again after rebooting. Not fun! If anybody has experience getting Bluetooth dongles (USB 2.0) working under Windows 98, PLEASE share your thoughts! Obviously, the newer the BT version, the better.
Regarding my videos, next I will make a video about getting USB file transfer and a wireless mouse to work on a Win98 rig, and after that a video about the Oplon gamepads. Wireless DS4s will be a video subject only when they work perfectly stable. 😀
Reply 28 of 46, by BX300A
Great thread. I love seeing a good Tualatin build. Your vids are nicely shot, excellent lighting. Keep up the good work.
386DX40, Amiga 600, Pentium 75, Celeron 300A, Pentium III-S 1.4, Athlon XP2400+, Pentium 4 I do not care for, Pentium M 780, Core 2 Q6600, i7 3770K
Reply 30 of 46, by khyypio
I couldn´t find any videos on how to get wireless mouse working on Windows 98, so here: https://www.youtube.com/watch?v=WAvUllPhWnQ
Edit.: Thanks, BX300A & foil_fresh! That means a lot!
Reply 32 of 46, by khyypio
I´m starting to feel like this is the never-ending project...
GeForce2 Ultra was part of my last upgrade last December, but I thought I might as well take it up a notch and found this GeForce4 Ti4200:
1.44 MiB
I have no idea what brand this is, don´t ask 😁 Someone in Facebook thinks it´s Palit Daytona... doesn´t matter to me, it works great. Since I was tired of my previous GPU fans screaming like nobodys business, I started to look for passive coolers and ended up with Zalman ZM80C-HP.
1.67 MiB
The original Teapo caps on my motherboard started to bulge and some of them were leaking. I replaced them with a nice set of Panasonic FR caps.
1.68 MiB
721.13 KiB
I wiped the leaking caps before taking the photos but the bulging is visible, although I know we´ve all seen worse. Still, why replace just one when you just have replace another later? Old Teapo caps retached:
737.62 KiB
Old Teapo caps
Reply 34 of 46, by khyypio
chrismeyer6 wrote on 2020-07-08, 20:40:
How are your temps with the passive heatsink? It's a great system your building.
Well, it heats which is good, means the heat transfer works like it should 😁 I didn´t measure any data to benchmark, but 3DMark 2001 demo has been running on loop for about an hour and the temperature has been steady for a while now. The cooler is hot but not too hot to touch, I can keep my fingers for a few seconds on it where the chip is located.
Reply 35 of 46, by bofh.fromhell
khyypio wrote on 2020-07-09, 17:08:
Just watched your video with the loud GF2-U fan.
There are brand new replacements available.
Just search for "Nv-1017".
Even matches the color of your Elsa!
Reply 36 of 46, by gex85
I really like those Zalman GPU heatsinks. I had one back in the day for my GF2 Ti and now I try to buy them whenever I can get them cheap.
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 37 of 46, by khyypio
bofh.fromhell wrote on 2020-07-11, 16:00:
Just watched your video with the loud GF2-U fan. There are brand new replacements available. Just search for "Nv-1017". Even mat […]
Thanks for the tip, I´ll keep that in mind!
gex85 wrote on 2020-07-11, 18:40:
Yeah, they are getting difficult to find. I got really lucky with mine.
Reply 39 of 46, by khyypio
Sketching custom wallpapers and splash screens...
1.21 MiB
1.77 MiB
1.38 MiB
