Reply 2680 of 5107, by appiah4
Nice system. Did you check the sound card? Those OEM builds can have some interesting cards inside..
Reply 2681 of 5107, by SpectriaForce
appiah4 wrote on 2020-02-13, 21:54:
It came without a sound card. Two card slot brackets were missing and a Matrox driver was installed, so someone has taken something out of it. It does have a 3COM NIC.
Reply 2683 of 5107, by SpectriaForce
LewisRaz wrote on 2020-02-13, 22:48:
SpectriaForce wrote on 2020-02-13, 19:24:
Finally I was lucky for once 😀
Nice system. Nice to see the OEM windows install too. For some odd reason I have a thing for OEM systems having the original installs on them.
That's certainly a plus, but it does need a reinstall or at least a thorough register cleaning, because some software has not been properly deinstalled. What I really like is that it doesn't have a CD-ROM drive and instead still the original slot cover 😀 #geek
Reply 2684 of 5107, by Deczor
Horun wrote on 2020-02-13, 03:28:
Deczor wrote on 2020-02-12, 23:26:
Crap. I'm dumb. It's working now.
The new replacement CMOS seems to be good too. Now I just need an AT keyboard.
Damn being in NZ, where you simply can't find stuff.
Great ! Nice find ! Do you have a PS/2 KB ? most will work with a PS/2 to AT adapter to an AT motherboard.
Yeah, I got a bunch of them. Only just realised you can get adaptors. Really don't want to give aliexpress my credit card number though. But will figure out something. 😀
Reply 2685 of 5107, by Horun
Finally I was lucky for once :) […]
I brought some optical drives to their last destination and took this HP Brio (you never see this model in the classified ads in my country for sale) from the e-waste container home today:
I've inspected it and cleaned it quickly this afternoon.
It has a Pentium MMX (probably 166 or 200), proprietary form factor i430VX board, 32 MB RAM, 2.1GB HDD and an onboard S3 Trio 'something'. A very typical 1997 pc (according to some date stamps inside).
To my surprise it works:
I'm going to keep this one, always nice to have a socket 7 system with a good motherboard.
Wow have not seen a beige HP mid tower in probably 10 years, nice find !
Reply 2686 of 5107, by HanJammer
Friend's dumpster find - I received this stuff in exhange for 486 build I'm completing for him.
Some damage unfortunatelly... but not on the items I really cared for (SCSI controllers, CGA card, 286 board) some of it I may fix...
Reply 2687 of 5107, by HanJammer
two more...
Reply 2688 of 5107, by appiah4
Ok now tell me where are these dumpsters?
Reply 2690 of 5107, by Horun
HanJammer wrote on 2020-02-14, 15:25:
Nice ! It looks like a 10Mhz 286 but the main Xtal looks like 48Mhz, so is it being overclocked to 12Mhz ? Just an observation and hope it works.
Reply 2691 of 5107, by EvieSigma
wiretap wrote on 2020-02-14, 19:52:
In dumpsters like this. […]
appiah4 wrote on 2020-02-14, 18:51:
Seeing that Compaq Alpha DS10 hurts me. Alpha stuff is impossible to find in Pennsylvania.
Reply 2692 of 5107, by wiretap
There's more than 1 in there, there are 3 more. I already saved 2.. don't have room for more at my house 🤣. DS20E's are next.
My Github
Circuit Board Repair Manuals
Reply 2693 of 5107, by Horun
wiretap wrote on 2020-02-15, 10:23:
Nice ! There is a place in my area where you can dump off old computers and they recycle the parts, have seen big bins full of old computers there BUT they guard it well and no non-employee can get near them or take anything. Wish I knew someone who worked there but am sure they have strict employee rules too.
Reply 2694 of 5107, by EvieSigma
Don't suppose I could get you to save one for me? 🤣
Reply 2695 of 5107, by HanJammer
Horun wrote on 2020-02-15, 05:47:
For now tantalum cap blowed into my face, and burned a hole in the carpet... It seems I will never learn to check them for shorts prior to applying voltage...
Reply 2696 of 5107, by luckybob
Popping tants is half the damn fun!
Reply 2697 of 5107, by Deunan
HanJammer wrote on 2020-02-16, 21:43:
I have a 386 mobo that powered up fine about 10 times and then both 12V and -12V caps failed - the 12V blew up and after that identified as a light bulb (a smoky and smelly one), while the -12V just kept silently tripping the PSU protection. So checking first is good but not exactly guaranteed to weed out the bad ones.
Reply 2698 of 5107, by canthearu
Deunan wrote on 2020-02-17, 00:56:
Need a bigger -12V supply then 😀
I did have a tant blow up on me in a 286 though. I've cleaned up the board but haven't put in a replacement cap. However, motherboard seems to work fine.
Reply 2699 of 5107, by H3nrik V!
From electronics scrap at work - must qualify as a dumpster find 😀
2 SBCs SiS630 Chipset, Tualatin-S 1133.
Rescued one last week as well ..
