Reply 320 of 459, by red-ray
pete8475 wrote on 2020-07-23, 15:46:
Ran that program, hopefully these screens show you what you want to know.
Thank you and yes, I have the same CPU and am pretty sure CPUZ ran OK on it last time I tried it. Can you boot NT/2K/XP on that system? If you can it would be interesting to see what Menu->Hardware->CPUID->CPU-0 reports, below is what I get on my CPU.
CuPid wrote on 2020-07-23, 18:01:
Thanks. It is strange because the K6-2 is supposed to support the MSR. Well ...
I assume it's MSR C0000087 it was trying to read and my identical Family 5 Model 8 (08) Stepping 12 CPU has it.
This makes no sense at all as my CPU should be the same and has C0000087, but your 'fixed' CPUZ no longer reports the FSB speed.
file.php?id=88561
file.php?id=88567
Reply 321 of 459, by pete8475
red-ray wrote on 2020-07-23, 20:03:
I'll load up XP on it and try that out shortly. Just need to find another CF card first.
EDIT - XP is installing now.
EDIT 2 - Forgive me if I'm a bit thick but I have no idea what these instructions are asking me to do "If you can it would be interesting to see what Menu->Hardware->CPUID->CPU-0 reports, below is what I get on my CPU." Do you want me to run CPU-Z in XP? If so what version and do you want me to run that other program too?
aka pete4237.5
Reply 322 of 459, by red-ray
pete8475 wrote on 2020-07-23, 22:00:
Thank you, it's really strange that your CPU does not seem to have MSR C0000087 and mine does.
With NT/2K/XP and later we can use an SEH (Structured Exception Handler) in our drivers to catch the 'BSOD' and deal with it so SIV should be able to tell if that MSR is there or not. SIV has Menu->Hardware->MSRs->MSRs K6 which should list all the AMD K6 MSRs that exist, but rather than post screen shots ideally post the two Menu->File->Save Local files as there may be other things I need to check.
Reply 323 of 459, by red-ray
It's just SIV32L V5.51 Beta-02 I wish you to run and does as attached help clarify?
Reply 324 of 459, by pete8475
red-ray wrote on 2020-07-23, 22:25:
It's just what SIV32L V5.51 Beta-02 I wish you to run and does as attached help clarify?
Yes it sure does! I had no idea there was a menu drop down if you clicked there.
I will do exactly what you want when XP is done installing.
aka pete4237.5
Reply 325 of 459, by pete8475
Ok ran SIV32X in XP and just out of curiosity the latest CPU-Z in XP as well (no crash).
Attached is the SIV32X report and a screenshot from the latest CPU-Z.
aka pete4237.5
Reply 326 of 459, by red-ray
pete8475 wrote on 2020-07-23, 23:53:
Thank you, but please may I also have F:\SIV32X\SIV_9590DF9758454F9.dmi (attach a .ZIP as .DMI is not allowed)? This is a binary dump of the raw data that the [Machine] page reports and I would like to so I can address SIV reporting 4 DIMMs when there are in reality only two. This is caused by the SMBIOS data being wonky.
Looking in the [msrs] section and at [CPUID CPU-0] then as I suspected MSR C0000087 exists so CPUZ-W9x should be able to read it and report the FSB speed.
In general reading MSRs on W9x is problematic, I just wish it was possible to use a SEH (Structured Exception Handler) as it the case on NT4 and later.
[msrs] [hardware]
 MSR   Value EDX : EAX      Value EDX : EAX      Value EDX : EAX      Value EDX : EAX    MSR  [Y]Current
0000: 00000000 : 00000000 00000000 : 00000000 :0003 [CPU-0 ]
000C: 00000000 : 00000000 :000F
0010: 00000055 : 9C65C638 :0013 [_]Select Total
0FFC: :0FFF [CPU-0 ] 4
C0000000: :C0000003 [CPU-0 ]
C0000080: 00000000 : 00000002 00000000 : 00000000 00000000 : 10010000 :C0000083
C0000084: 00000000 : E001FFE2 00000000 : 000001C6 :C0000087 [_]Select
C0000088: 00000000 : 00000000 :C000008B [CPU-0 ] Total
C00001FC: :C00001FF 6
[CPUID CPU-0] <- SIV32X - System Information Viewer V5.51 Beta-02 9590DF9758454F9::Owner
CPU-0 AMD-K6(tm) 3D processor (AMD K6-2 (Chomper)) [CXT]  STK 400.719MHz  CPU 400.719MHz  FSB 66.787MHz  L2 66.787MHz  WIN 400.000MHz
[Y]CPUID EAX EBX ECX EDX
00000000 00000001 68747541 444D4163 69746E65 [Y]"AuthenticAMD"
00000001 0000058C 00000000 00000000 008021BF [_]09 APIC 0x00 [_]16 Count 0 [_]15 CMOV [Y]08 CX8 [Y]04 TSC [Y]03 PSE
40000000 00000000
80000000 80000005 00000000 00000000 00000000 [_]" "
80000001 0000068C 00000000 00000000 808029BF [_]29 x64 Support [_]27 RDTSCP Support [_]26 1GB Large Page [_]20 Execute Disable
80000002 2D444D41 7428364B 3320296D 72702044
80000003 7365636F 00726F73 00000000 00000000
80000004 00000000 00000000 00000000 00000000 [Y]"AMD-K6(tm) 3D processor"
80000005 00000000 02800140 20020220 20020220 [Y]L1C 32KB 2-way 32-byte line [Y]L1D 32KB 2-way 32-byte line
80860000 00000000
C0000000 00000000
8FFFFFFF 4778654E 72656E65 6F697461 444D416E [Y]"NexGenerationAMD"
[Y]MSR EDX EAX Thermal 00000000 [_]16 TSCIV [_]17 SLAT [Y]00 Flags 0000000000008002
C0000080 00000000 00000002 IA32_EFER [_]11 XD Disabled [_]10 IA32e Mode Inactive [_]08 IA32e Disabled [_]00 SYSCALL Disabled
C0000087 00000000 000001C6 a 06 c 18 (x6)
[ OK ] [ Copy] [Windows] [Processors][Features] [Groups] [ NUMA] [ CPU-0] [Cache-0]
Reply 327 of 459, by pete8475
red-ray wrote on 2020-07-24, 07:52:
Sure, here it is.
aka pete4237.5
Reply 328 of 459, by CuPid
I've just released a new version of cpu-z vintage edition (1.02).
The new features are :
- AMD K5 model 0 (SSA/5).
- Improved support of Cyrix Cx486DRx2/DRu2.
- Improved support of Ti486SXL/SXL2.
- Intel 430FX chipset.
- Opti 82C822 chipset.
- VIA VT82C505/VT82C486 chipset.
Official version : https://download.cpuid.com/cpu-z/cpu-z_1.02-win9x.zip
Beta version : http://download.cpuid.com/betas/cpuz_w95.zip
I'm currently working on adding the support of ISA/VLB video cards, if you have such a video card and are willing to help, you can use one the two versions listed above, save a Video BIOS dump from the tools button, and post it here. Thank you !
I need a vacation.
Reply 329 of 459, by debs3759
CuPid wrote on 2020-08-11, 15:00:
Is this the PGA132 or PGA168 version? If PGA168, what board were you able to run it in? Never found a suitable board yet.
Reply 330 of 459, by CuPid
debs3759 wrote on 2020-08-11, 15:26:
Me neither, I have a PGA168 model and could never boot it.
For the software support I got the help of feipoa, he uses a PGA132 version.
I need a vacation.
Reply 331 of 459, by Camtheman
IBM PS/2 Server 95/A with P66
It can't identify the mainboard, funny 🤣.
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
Reply 332 of 459, by PiotrUU
ti 486sxl @ pga168 works on exp4349 see 8 page Re: Need help to improve the support of 486/586/686 class CPUs in CPU-Z
Reply 333 of 459, by CuPid
Camtheman wrote on 2020-08-19, 23:14:
Thanks for the report. Can you please post a TXT report ?
I need a vacation.
Reply 334 of 459, by CuPid
PiotrUU wrote on 2020-08-20, 16:31:
What about the PGA132 version ? Is it well supported by the latest 386 mainboards ?
I need a vacation.
Reply 335 of 459, by TechieDude
IBM PS/2 Server 95/A with P66 […]
It doesn't show any L2 cache either.
Reply 336 of 459, by CuPid
TechieDude wrote on 2020-09-03, 11:27:
Thanks for the feedback. Can you please post a TXT report ?
I need a vacation.
Reply 337 of 459, by TechieDude
CuPid wrote on 2020-09-03, 13:29:
I was just referring to the screenshot. I don't even have any Socket 4 hardware to test unfortunately. Sorry.
Reply 338 of 459, by Camtheman
CuPid wrote on 2020-08-24, 07:46:
Yep here you go. Report says I don't have any graphics adapters - This computer has an IBM XGA/2 with 1MB vRAM.
Reply 339 of 459, by red-ray
The CPU speed reported by CPUZ is to say the least incorrect 🙁 Even with just CPUZ active it's wonky.
file.php?id=92159
