Reply 320 of 440, by red-ray
- Oldbie
pete8475 wrote on 2020-07-23, 15:46:Ran that program, hopefully these screens show you what you want to know.
Thank you and yes, I have the same CPU and am pretty sure CPUZ ran OK on it last time I tried it. Can you boot NT/2K/XP on that system? If you can it would be interesting to see what Menu->Hardware->CPUID->CPU-0 reports, below is what I get on my CPU.
CuPid wrote on 2020-07-23, 18:01:Thanks. It is strange because the K6-2 is supposed to support the MSR. Well ...
I assume it's MSR C0000087 it was trying to read and my identical Family 5 Model 8 (08) Stepping 12 CPU has it.
This makes no sense at all as my CPU should be the same and has C0000087, but your 'fixed' CPUZ no longer reports the FSB speed.
