Reply 220 of 239, by CrossBow777
SpeedySPCFan wrote on 2020-03-09, 00:26:
the EdiRol SD-20, SD-80, SD-90, and E-MU Proteus 2000 series all don't have internal batteries thankfully, they use flash memory.
Yeap, there really isn't much at all inside of the SD-20 at least. I replaced the caps in mine late last year I believe it was. And with the exception of a few games or midi files, the SD-20 has just about replaced my MT-200 in terms of using it with games.
Midi Modules: MT-32 (OLD), MT-200, MT-90, SD-20
Reply 225 of 239, by thierry
derSammler wrote on 2020-05-24, 08:31:
Context? Or did you just posted some random words?
I suppose he meant that it has glue and it is not corroding, I don't know if I agree, my SC-155 had the battery changed and there was an acid thread that almost came off the logic board.
Reply 226 of 239, by derSammler
I assumed something like that, but it seems strange that someone with 9 posts in 9 years comes out of nothing claiming that this whole thread is moot and what we see is only glue. As if Roland (or any other company) would be so dump to put glue on a battery that firmly sits in a battery holder... It's of course leaked electrolyte from the coin cell.
Reply 227 of 239, by CrossBow777
cyberaxe wrote on 2020-04-07, 09:11:
Recently got an MT-32, SC-55 and SC-88, glad i saw this post, will open them up and check before I turn them on
The MT-32 doesn't have an internal battery unless it has been modified. But you might want to look into replacing the caps on it at some point as there are kits available for the MT-32.
Reply 229 of 239, by HandOfFate
Jackhead wrote on 2020-06-14, 12:36:
i checked my SC-88 Pro when i bought it, and the battery was leaking. Lucky there was no damage on the board..
*Gulp*. I didn't know the SC-88 Pro also has one. I'll have to check tonight.
My SC-55 did have a swollen battery but no corrosion or other damage, fortunately.
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 + Yucatan FX /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 230 of 239, by bjwil1991
Which reminds me. Gotta check my SC-55 to make sure the battery didn't leak as it's been sitting for a long time without power.
Systems from C64 to FX-6300.
Reply 231 of 239, by HandOfFate
Well, my SC-88 Pro battery seems to be fine. I'd like to remove it (it doesn't have it to remember any settings anyway) but I'm not sure how to get it out?
I can move it a little when I put a flat screwdriver under (or above) the battery, but it's difficult to see what I'm doing so I don't want to use too much force. Is there any trick to it? I'd rather avoid taking out the upper board.
Reply 233 of 239, by HandOfFate
Yeah, I guess I'll have to take it out then. I always try to avoid any chance of damaging things, but I guess it's unavoidable here 😀
Reply 234 of 239, by Dimitris1980
So,
1. Roland MT32 (old) does not have battery.
2. Roland Sound Canvas SC55 mark I has one, i have replaced it with new.
3. Roland Sound Canvas SC88 (not the pro), i guess it has, i will have to check it.
4. What about Roland CM64 and Yamaha MU50?
Reply 235 of 239, by keropi
MU50 has a battery but it's soldered AFAIK
CM64 does not have a battery
🎵Link to buy a PCMIDI mpu
🎧Orpheus soundcard project
💻WTB Amstrad PC7486SLC-33 system
Reply 236 of 239, by yawetaG
SC88 has the battery, in a holder (like most Roland gear).
Headless modules (no or minimum buttons on front) intended for use with a computer only usually lack a battery, and generally also lack persistent memory into which to save settings (patches usually are saved in the computer editor).
Reply 237 of 239, by yawetaG
HandOfFate wrote on 2020-07-14, 19:12:
Push back and flip up?
Some holders have a little slide you must move before removing the battery.
Reply 239 of 239, by HandOfFate
Having to put a tray on your bed in order to work on stuff. He must be living in a very cramped house.
Thanks for sharing the video. This will help 😀
