First post, by keropi
- l33t++
... well you should!
This is what I faced when I opened the SC-55 I received today:
A leaking CR-2032 battery! 😲 Fortunately the plastic holder prevented the acid from reaching the pcb...
Might worth to check your units, it would be a shame if they developed faults because of the battery. The situation is not as serious as the NiCad batteries that have killed countless mobos/amigas/etc , but still! Better safe than sorry 😊
