DosBox Requires Java
First post, by JamesJoey
I'll try this again.
I downloaded dbgl054.zip and put the contents of the zip in a folder called DosBox. When I run dbgl.bat I get the following error from DosBox:
'Unable to locate JRE meeting specification "1.5"
Sorry -- You don't seem to have the required version of the Java Runtime Environment [JRE] installed. DBGL requires at least JRE 1.5 to run.'
I downloaded and installed Java Runtime Environment 6.
I posted this problem here once but I seemed to have been abandoned.
Saying something about a 3rd party front-end. What ever that is.
If I can't get these old dos games to work I will most likely format the drive and revert back to Windows XP. Vista seems to be incompatable with much of my software.
James
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
You weren't abandoned though you're posting in the wrong forum for
the 2nd time.
Anyways, get the dosbox installer from
http://dosbox.sourceforge.net
It does NOT need any java.
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
It wasn't abandoned. It ended with an invitation for you to explain what your real problem is:
Which Java Runtime Environment to Use
I still don't know what it is you that you want to do.
And I am still waiting for a reply to my question to you about what java -version has to say.
_________________
