Mumak wrote on 2021-10-03, 21:48:
PC@LIVE wrote on 2021-10-03, 20:54:Hello an info on the fly.
I restarted a 386SX and I was wondering: can your program work?
I remember that it goes on the 386 but […]
I remember that it goes on the 386 but I don't know if it works on the 386SX, this being quite similar to a 286 (ie 16 bit instead of the 32 of the 386).
If it is possible I would like to try it these days, I currently have 2MB of ram, but if necessary I can easily bring it to 4MB by adding two other 1MB 30pin RAMs.
It will work on 386SX as the instruction set is important. 2MB might fit, but you'll need to try.
OK thanks for the info.
I connected the CF-IDE adapter that I use on the old-PC, the CF card is only 8MB, but despite this it is sufficient for starting some DOS programs.
HWinfo started up, a bit slowly because the Turbo is off (I guess), but it completed the various tests and created the files (which I attach).
But I have to find the definitive configuration, for this 386SX, I was thinking of adding an ISA sound card and another 2MB of RAM, I don't think the addition of the coprocessor is necessary, but it depends on the software that I will be able to use, if they require it to speed up processing , I might add it.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
