First post, by Bondi
I'm trying to make the TDK PCMCIA MIDI card work in DOS. It's a EMU8000 based card. It has a DOS enabler that sets port 2xx for synthesizer and 3xx for MIDI output port.
As I understand the EMU8000 has to be initialized and then it can be fed with MIDI data. This is what aweutil does.
Aweutil is hardcoded for port 620h, and all other ports are calculated on this base. I was able to change it to 220h. TDK card can be set to 220h as well.
But aweutil still complains that "Initialization failed" when I run it. Maybe it also performs some checks to make sure it's the AWE card present?
Don't know much about how it actually works with this regard.
I'd be grateful for any hints on this.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 2 of 3, by Horun
I think AweUtil requires a real Creative card. No luck on the TDK wbesites for DOS/Win3 drivers and not sure if this helps but the old Win3.1 drivers were saved to:
http://nwserveur.no-ip.org/win3xorg/devices/P … 208000/drivers/
Maybe there is something in those files that can help...
Reply 3 of 3, by Bondi
Horun wrote on 2021-09-25, 00:52:
Yes, I use this DOS driver to enable the card in DOS. I.e. it just sets the ports, and then windows driver takes over.
What I want is to stay within DOS. The functionality of aweutil seems to be very close to what is needed. But it probably checks if there is a real AWE card installed. I'm wondering if someone has disassembled it, and if someone knows how it works and what the AWE card check could be. Or maybe it requires some other functionality of AWE card to address the EMU8000 chip.
I've found several versions of aweutil and plan to see if it makes any difference.
