Reply 320 of 432, by AlexZ
Warlord wrote on 2021-09-26, 00:09:didn't get detected with pnp os on either.
A3config is not capable of configuring DMA/IRQ it seems. I had the same problem with ALS100+ and ALS120. It can only read the configuration, set volume and maybe a few other options. There is Intel ISA PNP tool that may be capable of configuring it and there is also universal config tool floating around on Vogons. With PNP OS ON in Bios setup Windows needs to configure the card before it can be used in DOS.
As far as noise level is concerned my Yamaha SM718 is quite noisy as well and I wouldn't recommend it to anyone to use with earphones.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
