Dedicated IPXNET + Nullmodem server software (C# .NET 10)
First post, by Myg
I put together this IPXNET + Nullmodem combo server from scratch recently.
The download is using C# and .NET (https://dotnet.microsoft.com/) from Microsoft .
If you have any suggestions/comments please don't hesitate to share.
Binary/Compiled Release
To run the Windows version, run "DOSBoxIPXServer" or double click the exe.
To run the Linux + MacOS version, run "dotnet DOSBoxIPXServer.dll"
JSON settings file (manually edit this for your setup):
If you accidentally delete the "Settings.json" file run the program and it will rebuild it in the same directory with default settings.
Settings.json
(default)
"MasterConnect": true,
"ServerName": "Default",
"IpxnetEnable": true,
"IpxnetUdpPort": 213,
"IpxnetUserTimeout": 180,
"IpxnetPingTime": 60000,
"NullmodemEnable": true,
"NullmodemTcpPort": 23,
"NullmodemListenBacklog": 30,
"NullmodemInitPoll": 1000000,
"NullmodemRoomJoinWindow": 60000000,
"NullmodemRoomTimeout": 60,
"NullmodemAvailableDelay": 1000,
"ExternalIpRefreshEnable": true,
"ExternalIpRefreshFrequency": 60000
I recommend using default settings unless you are having consistant connection errors.
MasterConnect - List your server on the master server list.
ServerName - Give your server a name on the master server list.
IpxnetEnable - Enable or disable IPXNET service.
IpxnetUdpPort - UDP port for the IPXNET service.
IpxnetUserTimeout - Number of seconds before a user is deleted from the IPXNET user list.
IpxnetPingTime - Number of milliseconds before a IPXNET ping test is performed (resets the IpxnetUserTimeout for clients who respond).
NullmodemEnable - Enable or disable the NullModem service.
NullmodemTcpPort - The TCP port which the nullmodem service will use.
NullmodemListenBacklog - The listen backlog for the Nullmodem TCP socket https://learn.microsoft.com/en-us/dotnet/api/ … n?view=net-10.0
NullmodemInitPoll - The polling countdown in microseconds for a basic security feature I use. Increase if you constantly have connection errors.
NullmodemRoomJoinWindow - The player 2 join window in microseconds (60000000 == 60 seconds).
NullmodemRoomTimeout - The number of seconds a nullmodem room has before it is closed and removed from the system if there is no activity.
NullmodemAvailableDelay - This number, in milliseconds, makes sure that the security data is fully received before processing. Increase if you constantly have connection errors.
ExternalIpRefreshEnable - Enable or disable the IP address refresh service.
ExternalIpRefreshFrequency - The number of milliseconds before the server detects if it has a new ipv4 address (for the IPXNET server).
How this works:
IPXNET - Just connect to the server as normal using the IPXNET commands in DOSBOX.
Nullmodem - There is a connection window between the first and second player. The first player connects using the serial + nullmodem command ("serial(port) nullmodem server: (server) port: (port)") and then the server waits for the second player in a given time window. If the time elapses before the second player connects it will reset back to the start and you will need to connect the first player again.
Reply 1 of 84, by Yesterplay80
Could you provide a compiled exe, please? I'd like to try it out but don't want to install the whole VS2017 suite just for it.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 2 of 84, by Myg
(snip + moved)
Reply 3 of 84, by Myg
I found a bug in dosbox that sends a packet type of 245 instead of the expected 32 (socket 213 + packetype 32 = 245): This has been causing problems and the inability to connect for some people who arn't on windows 10. I have implemented a work-around and the server should be operating well now (updated all the links).
My greatest apologies for not noticing this earlier.
Reply 4 of 84, by Vulturius
I've tested it out on my machine:
- running "DOSBoxIPXServerNF 10450 360 60000"
- running DOSBox Instance1 with "ipxnet connect 192.168.1.109 10450"
- running DOSBox Instance2 with "ipxnet connect 192.168.1.109 10450"
- Started up an IPX network game of Warcraft
Everything works great! Nice job!
Future tests I'd like to conduct is to run a server (DOSBoxIPXServerNF 10450 360 60000) and let others join over the internet?
I suspect I only need to open up port 10450 TCP/UDP on my network device?
Other question I have is, how difficult is it to be able to play games in DOXBOX and DOS over network IPX?
Reply 5 of 84, by Myg
Yep, you only need one UDP port open to the internet for it to work.
I dont know about using DOS and dosbox together.
Reply 7 of 84, by Myg
If you look at my design, you will see there is no need to restart or reset the server because it uses the internal IPX ping system to check if clients are still connected. I would suggest this functionality be built into the actual DOSBox exe for the IPXNET server itself instead of using a hard coded and limited client list.
Reply 8 of 84, by payfrayweagle
Hi Myg, how exactly does this dedicated server of yours work?
Reply 10 of 84, by Myg
New version has been compiled and released (.NET 5).
It should have from 50%-100% more efficiency then the previous version.
Reply 11 of 84, by Myg
It looks my host has messed up my hosting/domain and the server will complain with an error. If you get this error please wait till I have sorted this issue out with my host.
My apologies for any issues caused.
Reply 12 of 84, by Myg
Looks like my host fixed the problem, thanks.
Reply 13 of 84, by Myg
Updated with simplified mathematics.
Reply 14 of 84, by Myg
Updated with simplified logic and comments removed because the logic is too simple to really need them (unless requested).
Reply 15 of 84, by Myg
It has come to my attention that certain browsers like Chrome have been unable to download from my links so I am taking steps to correct that. I will update as necessary.
Reply 16 of 84, by Myg
Updated to Visual Studio 2022 community and .NET 6 (might take a couple hours to refresh).
Reply 17 of 84, by siljo
This is great!
Can you make one for serial1 nullmodem too?
Reply 19 of 84, by leonardo
Are you aware of ipxgw?
This apparently solves the problem of connecting DOSBox-clients with real DOS/Win9x systems on the LAN.
If you can make use of this solution and make the whole thing run on OpenWrt, you'll be loved by all and songs will be written about you. 😁
[Install Win95 like you were born in 1985!] on systems like this or this.
