First post, by Myg
I put together this IPXNET server from scratch recently. It is designed to be as fast, as simple (programmically) and as thread safe as possible.
The download is using .NET 5 (https://dotnet.microsoft.com/) from Microsoft .
If you have any suggestions/design comments please don't hesitate.
The download was built using Visual Studio 2019 Community edition.
Source: http://krock.online/files/DOSBoxIPXServer.zip
Reply 1 of 12, by Yesterplay80
Could you provide a compiled exe, please? I'd like to try it out but don't want to install the whole VS2017 suite just for it.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 2 of 12, by Myg
Compiled .NET 5 exe + dll: http://krock.online/files/DOSBoxIPXServerRun.zip
To run the Windows version, run "dotnet DOSBoxIPXServer.exe" or double click the exe.
To run the Linux + MacOS version, run "dotnet DOSBoxIPXServer.dll"
Normally loading it without arguments, will start the server with the default values:
- UDP port: 213.
- timeout: 360 seconds.
- pingtime: 60000 milliseconds.
Arguments: [port] [timeout] [pingtime]
[port] = UDP port that the server will use.
[timeout] = The number of seconds a client will persist on the server before it is removed.
[pingtime] = The number of milliseconds between ping checks: A proper responce will reset a client [timeout]
The arguements are all optional.
Examples/use cases:
- "DOSBoxIPXServerNF 5000" to run the server on UDP port 5000 with default timeout and pingtime.
- "DOSBoxIPXServerNF 5000 600" to run the server on UDP port 5000 with a 600 second user timeout with default pingtime.
- "DOSBoxIPXServerNF 5000 600 6000" to run the server on UDP port 5000 with 600 seconds user timeout with a ping/connection/keepalive test (resets the user timeout if successful) every 6000 milliseconds.
Reply 3 of 12, by Myg
I found a bug in dosbox that sends a packet type of 245 instead of the expected 32 (socket 213 + packetype 32 = 245): This has been causing problems and the inability to connect for some people who arn't on windows 10. I have implemented a work-around and the server should be operating well now (updated all the links).
My greatest apologies for not noticing this earlier.
Reply 4 of 12, by Vulturius
I've tested it out on my machine:
- running "DOSBoxIPXServerNF 10450 360 60000"
- running DOSBox Instance1 with "ipxnet connect 192.168.1.109 10450"
- running DOSBox Instance2 with "ipxnet connect 192.168.1.109 10450"
- Started up an IPX network game of Warcraft
Everything works great! Nice job!
Future tests I'd like to conduct is to run a server (DOSBoxIPXServerNF 10450 360 60000) and let others join over the internet?
I suspect I only need to open up port 10450 TCP/UDP on my network device?
Other question I have is, how difficult is it to be able to play games in DOXBOX and DOS over network IPX?
Reply 6 of 12, by DosFreak
DOSBox doesn't support talking to a real IPX network, you'll need find the patch and compile dosbox for that.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 7 of 12, by Myg
If you look at my design, you will see there is no need to restart or reset the server because it uses the internal IPX ping system to check if clients are still connected. I would suggest this functionality be built into the actual DOSBox exe for the IPXNET server itself instead of using a hard coded and limited client list.
Reply 11 of 12, by Myg
It looks my host has messed up my hosting/domain and the server will complain with an error. If you get this error please wait till I have sorted this issue out with my host.
My apologies for any issues caused.
