First post, by RobDos
I purchased of a local user a SB Awe 64 CT4380 and a SIMMCONN with 32MB EDO.
Every test I try I'm only getting 4MB of RAM from my AWE Card, this leads me to suspect the SIMMCONN or RAM is not functional.
I've also tested the same SIMMCONN on a CT4520 with identical results.
The memory module has the following markings
MT16D832G-6X 32MB EDO 60ns
modules : mt 4c4m4e8
The only thought I have is the SIMMCONN appears to be 'value' (I assume because the chip on the back has a V on it) and it needs to be gold?
I would expect the CT4520 to be a value card and the CT4380 to be 'gold' compatible?
I do not have any other 72 pinn memory to test with.
Can anyone confirm that I have the correct SIMMCONN firmware for the cards and to be superhelpfull link me to compatible memory on ebay? I found nothing with the listed chips from the old website but that's not really a suprise.
https://simmconn.tripod.com/manual.htm#Q3
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
