First post, by RobDos
I purchased of a local user a SB Awe 64 CT4380 and a SIMMCONN with 32MB EDO.
Every test I try I'm only getting 4MB of RAM from my AWE Card, this leads me to suspect the SIMMCONN or RAM is not functional.
I've also tested the same SIMMCONN on a CT4520 with identical results.
The memory module has the following markings
MT16D832G-6X 32MB EDO 60ns
modules : mt 4c4m4e8
The only thought I have is the SIMMCONN appears to be 'value' (I assume because the chip on the back has a V on it) and it needs to be gold?
I would expect the CT4520 to be a value card and the CT4380 to be 'gold' compatible?
I do not have any other 72 pinn memory to test with.
Can anyone confirm that I have the correct SIMMCONN firmware for the cards and to be superhelpfull link me to compatible memory on ebay? I found nothing with the listed chips from the old website but that's not really a suprise.
https://simmconn.tripod.com/manual.htm#Q3
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
Reply 1 of 14, by cyclone3d
The Gold! model AWE64 cards are CT4390 and CT4540.
Value models are CT4380, CT4500, CT4520 and CT4550
My guess is that the RAM is not compatible.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 14, by weedeewee
there's mention of jumpers in the manual, yet no mention of jumpers in OP's post.
Do not ask Why !
Reply 5 of 14, by weedeewee
ASP? that's the soundcard itself right ?
I was referring to the simmconn card since you linked to the manual.
Do not ask Why !
Reply 6 of 14, by RobDos
Sorry, yes the SIMMCONN is set for 32MB.
I reached out to the good folks at Serda Shop and they sent me this info.
It seems the 'value' is only listing 16MB modules as successful and it's a guess on the 'standard' version of the card.
the green V is a 'Value' firmware,
CT4520 is a value version, so this should work
CT4380 is a 'standard' version, i am not 100% sure, i think it would work as well with value firmware
for the memory, i cannot find this type in the simmconn thread, so maybe it is not compatible
From my site (https://www.serdashop.com/SIMMCONN), these are modules i know that worked for users :
Known working 32mbyte memory modules :
- HYUNDAI HY5117400C J-60
- LGS GM71c17400AJ6
- SIEMENS HYB5117405BJ-60
- OKI M5117405A-60SJ
- MIT 417409DJ EDO-60
- M.tec TBE1604A2A60
Reply 8 of 14, by RobDos
maxtherabbit wrote on 2021-11-04, 14:38:
I have an AWE64 Value (don't remember the CT number) and it works perfectly with a 32MB SIMM
Are you able to provide a link to the chips you used? I can't find any 32MB modules with the supported chips. I did order a 16MB one a few moments ago but I can always use a new keychain.
Reply 9 of 14, by maxtherabbit
RobDos wrote on 2021-11-04, 14:47:
I honestly have no idea. I just pulled a random 32MB SIMM out of my stack and it worked.
If you've already purchased a 16MB stick I would recommend you test that first to make sure the SIMMCONN works at all before buying anything else
Reply 10 of 14, by weedeewee
was easy enough to find this one.
https://ram-co-shop.de/32-MB-EDO-RAM-non-Pari … -TMS417409DJ-60
Do not ask Why !
Reply 11 of 14, by RobDos
Hey all, I wanted to provide an update.
Hi, I wanted to let you know because you were so kind to respond that I’ve tested with some other EDO memory modules I found around.
It recognized a 8MB of RAM chip that I installed in the CT4380 with the value firmware.
Without it it only recognized 512K
Oddly enough setting what I understood to be a 16MB chip to 16MB on the card only recognized 2MB
Dropping it to 8MB picked up 8MB in the diagnose utility but the memory chips are not listed as supported it will be a few more weeks for that as it takes a bit for stuff to get here from China.
While the ram-co-shop.de was the modules I'm looking for, it does me no go as they don't ship to Canada. Thanks for the link weedeewee.
The CT4520 I think is defective.
Thank you for the prompt reply, it’s greatly appreciated.
Reply 12 of 14, by georgel
RobDos wrote on 2021-11-16, 01:29:
Hey all, I wanted to provide an update. […]
If all tests pass with the DIAGNOSE.EXE utility then your card is *extremely unlikely* to be defective.
Reply 13 of 14, by RobDos
So I'm not having much luck here getting 28MB on this card.
I have a two different 32MB sticks, 16 and 8MB sticks I've tried.
Chip with 16x TMS417409ADJ
MT16D832G is one of the 32MB, when I configure the SIMMCONN for 32MB I get 2MB (card has 512k native)
Configure for 16MB, get 2MB
Configure for 8MB double sided, get 8MB
Configure for 8MB single sided, get 8MB
I'm losing my mind here, any ideas on what might be causing this? I just ordered another 32MB chip with 16x GD 51H0112
Is it's possible its a resource conflict?
Reply 14 of 14, by RobDos
4th's time is a charm!
Did not work:
MT16D832G-6X Micron 32 MB SIMM DDR SDRAM Memory
Chips: Chips 16x MT4C4M4E
But the latest chip, assembled in Canada no less worked and passed!
Celestica 32MB EDO
Chips: GD 51H0112
Thanks for the help all!
    334.91 KiB
