First post, by Garrett W
Greetings!
I have a Kingston TurboChip TC366 which used to house an AMD K6-2 366. As far as I can tell, this is a voltage regulator that runs in-between the board and CPU, so as to make sure that the correct voltage is applied. In the case of the K6-2, I believe that CPU required either 2.2v or 2.4V, where as MMX capable boards from that era usually supply 2.8V, maybe 2.7V. Not to mention boards that are incapable of dealing with split voltage and just do 3.3V-3.5V.
In any case, I've had this adapter for many years, but I have never made use of it or even tried it. I got my hands on an Olivetti M24 🤣 a few days ago which I upgraded from an MMX 166 to a 233, however I have a K6-2 450 that I've been thinking of plugging in, in the hopes that I can get it to work at 400, effectively maxing out the CPU for this system (with the possible exception of a K6-III or one of the plus models). The mainboard unfortunately can't do voltages lower than 2.8V, so I've been thinking of using the Kingston TurboChip adapter/regulator to do the hard work there.
Thing is, beneath the socket on the adapter/regulator is a set of 8 DIP switches without a map for the possible combinations. Tried as I might, I could not find any manual or explanation for these switches. Kingston's official manuals do not mention the DIP switches, I don't think they wanted end users removing the CPU from the adapter and only used them internally to configure for different products. The only clue I have is an IC next to the DIP switches which reads:
"f P86AB
RC5036M
A"
Unfortunately, I could not find any datasheets for this. I'm attaching two photos of the TurboChip in the hopes that someone can help me figure out the possible combinations.
Reply 1 of 41, by BitWrangler
I would say there's likely to be three multiplier switches, like on a motherboard, but overriding the motherboard ones, that go to the pins on the top CPU socket, and they are likely to have 10Kilohm resistors on them. Then there's likely to be 5 for setting voltage on that chip you see, which probably have a variety of different resistance values and work like voltage settings on a lot of motherboards. So if original docs are not to be had, you can bleep out the multi pins from a CPU pinout and figure out the voltage settings from the datasheet of the chip and the resistance values.
Reply 2 of 41, by snufkin
I found a datasheet for the RC5036: https://www.datasheets360.com/pdf/635297678915034898
Page 9 has an example/refernce circuit, which Kingston may have followed and could be useful to work out what the switches connect to.
Reply 4 of 41, by Sphere478
I’m trying to figure out jumper settings on mine, did you have any luck?
I can find manuals for it but no dip settings listed..
Sphere's PCB projects.
Reply 6 of 41, by snufkin
I think as Bitwrangler suggested, that if the manuals don't include DIP switch settings (they're factory set and sold with CPU fitted, so probably not), then it's going to mean working out what's connected to what. Better photos would help, showing the resistor values. Some traces will show what the connections are, and knowing resistor values might mean it's possible to make a guess about which the voltage output resistors are, based on the Vout=1.5*(1+R1/R2) given in the RC5036 datasheet (same formula for both outputs). But there will be enough traces going under components that any guess will need to be confirmed by checking.
Reply 7 of 41, by Sphere478
Garrett W wrote on 2021-12-20, 10:39:
Unfortunately not, the motherboard I wanted to use for the K6-2 did not support the processor properly so I gave up on the subject.
Ask user chkcpu to mod your bios if it isn’t listed on his website (jan)
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
Reply 8 of 41, by Sphere478
snufkin wrote on 2021-12-20, 12:19:
On mine I’m pretty sure that the first three left to right are probably the bf0, bf1, bf2 registers for setting multiplier
And the rest to the right I’m pretty sure are the voltage settings
Assuming that it works like any old socket 7 motherbord all off should give the lowest voltage and probably from left to right should be +.1v, +.2v, + .3v+, .4v, +.8v or something like that
I’ll have to do some experiments
Reply 9 of 41, by rmay635703
The 3 clkmul pin positions on the cpu/socket are in known positions
You could on a bench use an ohm meter testing each clkmul pin by flipping every dip switch one at a time to see which dip attaches to which clkmul
If I had to guess the 3 dipp switches that are up relate to the 5.5x multiplier and unless you want to use 6x there is likely little reason to change them
The other dips likely affect other things like voltage and it’s doubtful they go below 2.2v
Reply 10 of 41, by Sphere478
rmay635703 wrote on 2021-12-20, 19:42:
The 3 clkmul pin positions on the cpu/socket are in known positions […]
I am suspecting that my adapter in it’s curent state is likely in the 5.5x 2.2v or 2.4v configuration but I am unsure.
Do you know what pin configuration is required for 2/(6x)?
I can totally figure that out with a volt meter if I have some references to go off of
Edit: confirmed it’s set to 2.2v
    1.61 MiB
Reply 11 of 41, by Sphere478
Okay 4-8 are voltage switches as suspected
All voltage switches off is 2.020v so this is the base
4 is +0.1
5 is +0.2
6 is +0.4
7 is +0.8
So 2.8v is all voltage switches off except 7
But it gets weird, there appears to be a second tier of voltage settings if you enable switch 8
The second tier has a base of 1.330v
With this new base setting the switch values are cut in half. The +.1v is now a +.05v and so on.
So it seems this adapter can set about whatever voltage you might want!! Awesome!
Ps, not that this would ever happen but be sure power is fully removed when setting these switches, I noted a glitch wherein if full power down wasn’t observed between settings that the regulator would let 5v through instead of the set value.
I can’t imagine a scenario where someone would plug a cpu into a running computer though. But heads up 🤣
Reply 12 of 41, by Sphere478
Can someone ⭕️ the pins I need to check for those final three switches? Not clear on which ones they are
Reply 13 of 41, by snufkin
That voltage pattern rings a bell, and it appeared on some motherboards: Super socket 7 motherboard voltage jumpers.
BF pins are here:
105.59 KiB
Settings are here:
32.49 KiB
Reply 14 of 41, by Sphere478
Okay, I can see 2.020v on all the vcc2 pins and these two images appear to be in the same orientation
Reply 15 of 41, by snufkin
Sphere478 wrote on 2021-12-20, 20:16:
I showed the bottom view of the CPU, forgetting you'd actually want the socket. I think this is right:
91.31 KiB
Reply 16 of 41, by Sphere478
Switch 3 is bf
Switch 2 is bf1
Switch 1 is nc (in line with other two pins)
Basically they flip orientation when looking head on a the three switches and pins.
I assume bf is bf0, bf1 is bf1 and nc is bf2
So what settings are required for 2x?
Reply 17 of 41, by snufkin
Sphere478 wrote on 2021-12-20, 20:30:
Switch 3 is bf Switch 2 is bf1 Switch 1 is nc (in line with other two pins) […]
Switch 3 is bf
Switch 2 is bf1
NC? It looks like switch 1-3 go to R6,7&8 (330 ohm). Seems unlikely they would fit all three resistors for one to be NC. Datasheet (I edited post just above yours earlier) says 2x/6x is BF[2..0] = 110b.
[edit: just looked up the datasheet for the 5057 and it gives the 5 bit voltage table there, seems to match what you found, 1.30V to 2.05V in 0.05V steps, then 2V to 3.5V in 0.1V steps. It's actually quite a different design from Garret's]
Reply 18 of 41, by Sphere478
snufkin wrote on 2021-12-20, 20:36:
Switch 3 is bf
Switch 2 is bf1
Nc is the label for the right most bf pin on the schematic I uploaded.
I don’t understand
Edit, ohh! So we want bf 0,1 on and bf2 off?
Reply 19 of 41, by snufkin
Sphere478 wrote on 2021-12-20, 20:39:
Nc is the label for the right most bf pin on the schematic I uploaded. […]
I don’t understand
Ah, missed that, I'd already downloaded a pinout that had them labeled BF2, BF1 and BF0.
Not sure how to describe this, but when giving the setting of a bus of several lines, like BF[2..0], the setting will be in the same order as given in the square brackets.
So BF[2..0]=abc means BF2=a, BF1=b and BF0=c. So BF[2..0]=110b (b for binary, would also make sense to give it in octal/hexdecimal) mean BF2 and BF1 set to '1' and BF0 set to '0'.
