Reply 41600 of 58600, by RaiderOfLostVoodoo
I won an auction for a scrap lot for 30€.
Most interesting piece: A Voodoo 1 from Diamond. Gotta have to earn my name!
Lets hope it works or can be restored.
Reply 41601 of 58600, by TrashPanda
RaiderOfLostVoodoo wrote on 2021-12-20, 11:34:
heh hope so, cant let a good Voodoo go to scrap like that.
Reply 41602 of 58600, by RaiderOfLostVoodoo
TrashPanda wrote on 2021-12-20, 11:38:
Just what I thought!
There was another lot from another seller. 10kg of scrap. Also with a Voodoo 1. But that went for 70€.
Also the moron ripped out the socket with the CPUs, cuz time is money! -.-
Reply 41603 of 58600, by TrashPanda
RaiderOfLostVoodoo wrote on 2021-12-20, 12:52:
Just what I thought! There was another lot from another seller. 10kg of scrap. Also with a Voodoo 1. But that went for 70€. Also […]
Would take more time to rip it out than to just take the cpu out, them sockets are sturdy.
Reply 41604 of 58600, by GigAHerZ
Few days ago met another local retro-pc (and some consoles) person, who gave me a Trio32 VLB videocard, which was a good improvement over my CL-GD5429 based VLB card on my 486 pc. (Quake benchmark went from 16.1fps to 16.5)
Even though he just gave it to me, i promised that this is not the end of the deal and soon we'll find something i have and he needs. 😀
Reply 41605 of 58600, by Dimitris1980
Today I got the present of one of my colleagues, one Amiga 1200.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 41606 of 58600, by xcomcmdr
Wow, thanks for the photos ! I'm glad that it still works. It will serve you well ! 😀
Reply 41607 of 58600, by BetaC
I managed to pick up a Twin Turbo 128 graphics accelerator for PowerMac models that I don’t yet own. Sure it could be put in my G3, but there’s no point to that really.
The attachment 8A649B70-85C6-4C4A-89D2-E6976B94C559.jpeg is no longer available
My 7100/80 is nubus only as well, so literally nothing can put this to actually useful use.
Reply 41608 of 58600, by bjwil1991
Bondi wrote on 2021-12-12, 08:18:
bjwil1991 wrote on 2021-12-12, 07:11:
Bought/won a pair of MediaVision LPT sound cards on eBay. […]
Seller's photos:
The yellowed one needs attention and the other needs a good sticker residue removal. Going to test them on a laptop that has a crappy sound card.
A good buy! I saw this listing, but did not realize it was for two devices.
Audioport has a Yamaha OPL chip and Sound Blaster support, but IIRC SB works only in Windows. Please keep us posted on testing results.
I got them this afternoon and sadly, I cannot find the drivers that'll work with WFW 3.11 at all. When I try to run the install program, it says to run the Multimedia Extensions first.
Any idea of how to fix that?
Reply 41609 of 58600, by Bondi
bjwil1991 wrote on 2021-12-21, 06:37:
Seller's photos:
Not sure what the problem is. I tried to install the attached drivers to WIN 3.11 in DOsbox and they insatlled with no issues.
The only guess I have is that it needs Windows Sound System installed first.
The attachment MV_AUPRT.ZIP is no longer available
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 41610 of 58600, by bjwil1991
I got it to install (the drivers using the control panel) after I got the power brick situation fixed.
Good news: it works in WFW 3.11
Bad news: doesn't work with DOS anything still and the install.exe doesn't work still.
I have a hunch that I need the 3 diskette set to get the adapter to work correctly.
Reply 41611 of 58600, by Bondi
bjwil1991 wrote on 2021-12-21, 08:21:
I got it to install (the drivers using the control panel) after I got the power brick situation fixed. […]
I'm sure someone on the forum has a complete set. Cyclone3D IRRC had one.
Reply 41612 of 58600, by Thandor
OMORES wrote on 2021-12-19, 13:15:
This Number Nine video card (Savage4 Xtreme) with an unusual DVI to VGA implementation...
The card works!
Working…. Eight days a week!
Look closely against a light 😉
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 41613 of 58600, by Hirsch
I received my last Mouser order today. Yummy organic polymer capacitors from Kemet and Nichicon for recapping two DFI K6XV3+ / 66 mainboards.
Reply 41614 of 58600, by OMORES
This Sun motherboard with 512MB SD-RAM and a 440Mhz UltraSPARC CPU...
The ATX connector looks like a very standard one, but it's not ... (or maybe I have to try an older PSU)
What If a Modern GPU Had 1990s Bandwidth?
Reply 41615 of 58600, by BitWrangler
Working with a rusty memory here, haven't done it recently, but I think you need to go to control panel and install the windows components that support sound and multimedia. (Will need the disks or a directory with all the .cab files)
edit: derp, guess you did that, just read following posts.
Reply 41616 of 58600, by subnet_zero
OMORES wrote on 2021-12-21, 14:03:
Nice board. The connector looks very similar to the ones Dell had: A Permanent Solution to the Dell 'Fake ATX' Power Supply Problem?
Reply 41617 of 58600, by dionb
Sure it's not ATX? Did you have the AUX connector plugged in too? If not, that's your problem.
Here's a pic of an Ultra 10 with PSU hooked up:
The attachment sunu1013.jpg is no longer available
And here's ATX pinout:
The attachment connector_atx_pinout.GIF is no longer available
Perfect match with the ATX 1.x 20p connector. But that AUX-connector next to it is non-optional on the Sun systems.
Reply 41618 of 58600, by RaiderOfLostVoodoo
Hirsch wrote on 2021-12-21, 12:43:
Looking forward to receive my K6XV3+/66 back. 😀
Reply 41619 of 58600, by debs3759
Not exactly computer hardware or my own purchase, but a friend I forward stuff to from here in the UK just bought me 3 sets of metal shelving to finish reorganising my collections. An awesome gesture from someone I only know online.
https://www.ebay.co.uk/itm/222779509044 (I hope it's OK to post a link showing what shelves I use)
