Reply 20960 of 30772, by dormcat
RaiderOfLostVoodoo wrote on 2022-02-19, 12:34:
Boards that can run EDO can usually run FPM as well. […]
It's always a good idea to check all your RAM modules.
Don't forget to take a photo of successful Memtest, in case you want to sell.
I have photos of all my sticks, even the ones I intend to keep.
To be more exact: I don't have any motherboard with 30-pin (FPM) or laptop with 144-pin (SO-DIMM SDR SDRAM) now. The only 30-pin socket I own is on the sound font expansion of SB AWE32.
I do have a single strip of 4MB 72-pin FPM SIMM (70ns) but I can't install on a Pentium-class MB as they require SIMM in pairs, and I don't have (nor I plan to acquire) a 486 MB with 72-pin SIMM socket just to test this RAM.
Kinda regret recycling a 486 MB (had power-up issues and didn't know how to convert ATX to AT; my remaining 30-pin SIMM were taken down from it) and a Win9x laptop; didn't have enough time and knowledge back then.
Reply 20961 of 30772, by PD2JK
You could buy a 72p RAM expansion board for AWE64. Then you can test single modules.
No guarantees above 28 Megs. 😁
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 20962 of 30772, by stef80
Refurbished another FX5900 XT 😀
The attachment IMG_20220220_115738.jpg is no longer available
The attachment IMG_20220220_121409.jpg is no longer available
Reply 20963 of 30772, by stamasd
Recapping a socket 939 board.
Silly cap, you're supposed to be 3300uF, why'd you have to burst like that?
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 20964 of 30772, by fosterwj03
I wrapped up my experiments with OS/2 version 2.0 with Service Pack 2 (Fixpak?) on my Pentium 4 overkill retro box. I was surprised to learn that the OS/2 multimedia pack that shipped with OS/2 2.1 will install and function on version 2.o (at least with the Service Pack). I couldn't find much documentation online that it was even possible other than references to an IBM multimedia computer that shipped around the same time. Even better, the improved Sound Blaster 16 driver from Creative Labs works perfectly including the "external MIDI" from the attached Dreamblaster S2.
The only problem I encounter was that I couldn't get sound FX working properly in either DOS or WIN-OS2 (version 3.0a). I could get a Windows CD player to work with analog stereo sound, but I couldn't find a Win 3.0 sound driver that would properly detect the Sound Blaster 16 in Windows (it complained at the DMA detection stage).
Creative Labs "DIAGNOSE.EXE" program properly detected the Sound Blaster 16 in a DOS box and even played the test 8-bit and 16-bit sounds as well as ADLIB music. Unfortunately, every game I tried either crashed the DOS box or crashed the system if I tried to play with sound FX. General MIDI through the Dreamblaster S2 did work in most games I tried in a DOS box.
For good measure, I also installed networking with TCPIP. I could basically only run Ping and FTP, but it still provided some internet capability.
I wish I knew how to screen capture in OS/2 on real hardware. The only screen capture utility I could find for OS/2 version 2.x captures text boxes, not the desktop. I'd love to show off OS/2 in all of its 1280x1024, 256-color glory (using an ATI Mach32 graphics card).
Reply 20965 of 30772, by BitWrangler
Even late in the life of OS/2 I think programmers would have thought storage performance so low in comparison to data capture required, that it would be pointless, even at 5 frames a second. Any real time compression would be out also, didn't have the Mhz for that either.
Reply 20966 of 30772, by Kahenraz
stamasd wrote on 2022-02-20, 21:25:
Those are probably low ESR capacitors. Make sure that you replace them with the right ones.
Reply 20967 of 30772, by stamasd
The ones I'm getting are rated for ESR of 0.015 ohms, should be good enough.
I/O, I/O,
I/O, I/O
Reply 20968 of 30772, by stamasd
Recapping a socket 939 board. […]
Okay after recapping the motherboard, it works... sort of. I mean it works, POSTs and boots consistently, I can get into the BIOS without it freezing etc.
But it takes a very long time to POST. Like, 5 minutes long between printing the CPU ID and the moment when it starts counting memory. After it starts counting the memory, all is fine and proceeds at the normal speed.
And it does this delayed POST very consistently, every single time. I've never seen a motherboard do that.
I/O, I/O,
I/O, I/O
Reply 20969 of 30772, by Nexxen
stamasd wrote on 2022-02-22, 00:15:
Okay after recapping the motherboard, it works... sort of. I mean it works, POSTs and boots consistently, I can get into the BIO […]
What happens if you press reset?
Cold boot, hot boot; resets? I guess you tried all already.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 20970 of 30772, by stamasd
Reset gives cold boot. But even a warm boot (ctrl-alt-del after boot) results in the same long delay during POST. Just without memory count at the end of the delay.
I/O, I/O,
I/O, I/O
Reply 20971 of 30772, by Kahenraz
I have a motherboard that I recapped which doesn't shutdown or reboot properly from Windows 98/ME. Shutdown will usually work but reboot will always hang the system on a black screen with a blinking cursor, requiring a hard reset. Either option will always trigger the startup scandisk which detects an incorrect shutdown (even though normal shutdown turns the computer off completely).
I only noticed this problem after I replaced the stock capacitors. I used genuine Nichicon capacitors ordered from Digi-Key. I don't know if the issue existed prior to replacing the capacitors since I hadn't done this exact test.
I have suspected that the capacitors I used as replacements are not low ESR, which is why I offered the warning. The ones I used are Nichcon HV(M) series which are marketed as low impedance. I'm not even sure if this has anything to do with the problem I'm experiencing, as I only have the one board.
Reply 20972 of 30772, by stamasd
Well I've cleared the CMOS a few times, didn't help. Flashed the latest BIOS version 1.D from the original 1.A and it also didn't help.
I noticed that during the time it waits during POST, if I press the NumLock key, all 3 LEDs on the keyboard flash, then go blank. Do this 5-6 times in a row, and eventually it continues to POST. So it shortens the duration of the wait during POST. Weird.
I/O, I/O,
I/O, I/O
Reply 20973 of 30772, by Kahenraz
You're in the same boat as me now. Without a working motherboard with the stock capacitors, we have no way of confirming whether or not this is the original behavior.
Reply 20974 of 30772, by stamasd
I guess I'll go ahead and install XP and see if it's stable. 😀
I/O, I/O,
I/O, I/O
Reply 20975 of 30772, by ODwilly
Kahenraz wrote on 2022-02-22, 01:10:
The last time I put my Soyo P4 board through it's paces was after the VRM recap, since then Iv done the rest of the primaries and big-medium secondary caps and the power switch wouldn't power it off, but the reset switch worked perfectly. However if I tried to put it to sleep it would soft crash XP
Reply 20976 of 30772, by TheAbandonwareGuy
Anybody familiar with a DEC Dazzle Multimedia Rev 3 PCI card? I got this thing in a lot and I can find precisely fuck all about it. Apparently it was made in 1997 with a Digital Multimedia 21230 at its core from 1995 (https://techmonitor.ai/techonology/dec_chip_h … desktop_editing) with what appears to be 1MB of Alliance memory on the back end. Just a fancy MPEG1 card I'm guessing? Any practical usage?
Also acquired a Rage 128 AiW, a Matrox G2+ with memory expansion module, and a SB Live 5.1 in the same lot. Not bad for something I received for free.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 20977 of 30772, by stamasd
I guess it may help if you plan on using your retro machine to make and playback VCDs. 😀
I/O, I/O,
I/O, I/O
Reply 20978 of 30772, by Nexxen
stamasd wrote on 2022-02-22, 01:38:
What happens without a keyboard? Same 5 minutes wait?
Reply 20979 of 30772, by stamasd
I didn't try that. I may do it tonight when I get home. I did set the CMOS to "halt all errors except keyboard" so that should work.
FWIW I set the above because, at first POST after recapping, it gave me a "keyboard error, press F1 to continue" - despite the keyboard working fine, pressing F1 got it past that etc. This is also a keyboard that works flawlessly on all other retro machines I have (a dozen or so). Come to think of it, after I flashed the newer BIOS it did not give me that keyboard error anymore, but I still set that parameter in the CMOS anyway.
I/O, I/O,
I/O, I/O
