Reply 120 of 237, by Dege
Thx, I fixed it and reuploaded WIP85.1.
Display ROI, Resampling and Cursor scale factor are only enabled when the scaling mode is one of the those that are 'done' by dgVoodoo itself.
Greying in/out is re-done when the scaling mode changes so you shouldn't restart the cpl. In the explaining tooltip I mention "scaling done by the wrapper".
But if the controls are disabled then the tooltips won't appear, it's the Windows default working mode.
