Dual PIII-S Tualatin 1.4 GHz Success Stories
Reply 240 of 327, by Paadam
My P3TDE6 runs GT6800 AGP perfectly, AGP 2x but no need for any special drivers or hacks, OS is XP Pro SP3.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 241 of 327, by adalbert
HD4650 AGP works fine on 6VXD7 (with pin-modded CPU). I have Via 694x chipsed with AGP 4x enabled in BIOS. The only problem is that GPU-Z (I only tested the most recent version) crashes the PC, but I didn't experience other problems. You can even play Source games in 1080p with somewhat playable framerates https://youtube.com/playlist?list=PLHYhIwP-NS … HokxJoJNAI2Xven
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 242 of 327, by Paadam
I was referring to the problems usually associated with Serverworks chipset equipped boards with AGP port.
Reply 243 of 327, by feipoa
Paadam wrote on 2021-02-08, 17:10:
At least on that Supermicro dual Tualatin Serverworks board, AGP 2x seems to function, whereas on the Tyan Serverworks board it must be set to AGP 1x to get reliable operation. I've been meaning to benchmark the AGP results on these dual Tualatin board and compare them with conventional single-core Tualatin boards, which presumable have AGP implemented a bit better. I'm hoping that the dual channel SDRAM might make up for any AGP shortcomings.
I find those Supermicro Tualatin boards problematic in general. I went through 3 before I found one that worked.
Reply 245 of 327, by Paadam
Mine got ~11k points with stock clocks in 3DMark2001SE, nothing overclocked. Seems good enough for me.
Reply 246 of 327, by Mamba
Do not know if it is a success or not, but one of the forum users sent me two P3-s that completed my pro266td build.
I am not able to change cpu voltage.
It can take a hd4650 but appears to be incompatible with hd3850... Strange...
Here what it can do (3gb and mass effect launched without issues)
Reply 247 of 327, by MadYoshi
A new success story,
two Pentium III-S 1,40 GHz on a Intel SDS2.
The attachment IMG_20220227_213938.jpg is no longer available
The attachment CPU-Z.jpg is no longer available
Bios version 3.0 is currently still on my SDS2. The latest version is 3.2. I've already rummaged through archive.org, but unfortunately I couldn't find a downloadable link. In case someone might have saved the bios file with them, I would be very happy about it.
The information I was able to extract from the Intel Bios File page is as follows:
SDS2_BIOS Release 3.2 Build 52 [BIOS52.EXE]
Date: 8/8/2003
Reply 248 of 327, by PC Hoarder Patrol
MadYoshi wrote on 2022-03-16, 00:21:
A new success story, […]
Date: 8/8/2003
Here you go
The attachment BIOS52.exe is no longer available
Hoping to snag a couple of these baords (and a pair of STL2s) shortly.
Reply 249 of 327, by luckybob
Good luck with that, ebay trolls have snatched up any boards that were remotely affordable, bumped the price to asinine levels and will sit on them until they rot.
Reply 250 of 327, by PC Hoarder Patrol
luckybob wrote on 2022-03-16, 18:42:
Boards are already secured (just not to hand yet) and none will get the chance to rest inside an anti-static bag for long 😀 but yeah, ebay is pretty much a bust for so much now (4 figures for an SDS2 - holy hell what are these people thinking!!!)
Mine have come thru a trade (goods + services) from my own circle of contacts; probably average $50-75 a board, plus a bit extra for some cpus & ecc memory, and that's the kind of level for these I tend to move them on at as well thru the same route.
Reply 251 of 327, by luckybob
I used to own an sds2, it ran as my first file server 20 years ago. I wish I had kept it.
I do have the Tyan version, and the unobtainable asus trl-dls. (Thanks Liqmatrix!)
I will admit I have several ebay saved searches, for the sds2. I need to restore the trifecta. ^.^
Reply 252 of 327, by sirotkaslo
which coolers are you using for your tualatins? I have the MSI pro266TD master LR and it got horrible caps positions. I unfortunately broke the clip on one of the oem coolers and need something new. I have titans, golden orbs, but nothing really fits 😀
thanks
Reply 253 of 327, by luckybob
I have a bunch of these: https://www.alphanovatech.com/en/cat_pfe.html#spec_pal
Reply 254 of 327, by sirotkaslo
This one will be hard to find. I’m looking at volcano 6. But they are ofc used 😒
Reply 255 of 327, by Errius
luckybob wrote on 2022-03-17, 10:24:
what forces manifest when all three are joined under the same roof?
"AI Requires Proof That You Are Human"
Reply 256 of 327, by MadYoshi
PC Hoarder Patrol wrote on 2022-03-16, 02:26:
Here you go […]
Date: 8/8/2003
Here you go
BIOS52.exe
That it is! Thank you 😀
Reply 257 of 327, by luckybob
Errius wrote on 2022-03-17, 20:18:
I'll send a buff little twink after Ganon?
Reply 258 of 327, by MadYoshi
The Intel SDS2 got a graphic card.
The attachment IMG_20220726_182252_2.jpg is no longer available
After cleaning the cooler, i will make some benchmarks.
Reply 259 of 327, by Sphere478
looking sharp!^
Mamba wrote on 2021-04-26, 06:15:
Do not know if it is a success or not, but one of the forum users sent me two P3-s that completed my pro266td build. I am not ab […]
Re: Socket 370 Tweaker
some info here about how you may be able to change voltage via pin mod
Sphere's PCB projects.
