First post, by A.W.G.
Hello all,
I'm writing here, because I'm new to dosbox and I have an invtro to "The Gathering '99", which runs under DOS and needs dos4gw, but I can't start it.
When I start it, it hangs, when I press "Space" then it is possible to change the soundcard-settings, but when I leave these settings it hangs again. All I can do then is pressing "Space" or another key again to change the sound-settings again, but this isn't of course what I want.
So I'm asking here the pros, who have much experience with dosbox if some of you can download the invtro and maybe get it to run?
Then it would be great, if you could post a reply here, how you managed it to run flawless at your computer!
You can download the invtro here:
http://www.scene.org/file.php?file=%2Fparties … nv.zip&fileinfo
Greets to all
Alex
