First post, by DesktopDynamite
- Newbie
Hi all,
I would like to build a rig to be able to run both DOS [from 93' ish] and Win9x games.
SPECS:
Asus P3B-F Slot 1 with latest beta BIOS [Intel 440BX based]
512MB RAM
Pentium III 500Mhz Katmai [can set speed to 333Mhz from BIOS]
Voodoo 3 2000 PCI
Creative AWE64 CT4520 value ISA card
For OS I have an IDE2SD reader card with a 4GB SD card with Win98SE and another 1GB SD card with MS-DOS 6.22 with Phil's MS-DOS starter pack.
I have also the Yamaha YMF-724V PCI as per the attached photo, which I currently removed to make sure that the above is set correctly.
Excuse my noob questions [coming from the Amiga scene...], but can these be set to run in one machine and let me choose which I want to use ? For example the set the music to be output from Yamaha card and the SFX from the Creative card or I will complicate things more?
Maybe someone here hava a similar combined specs and can guide me please?
Thanks in advance!
