First post, by Rodney Betters
Playing Morrowind GOTY edition (which is fully up-to-date) on Windows XP with a Core 2 Quad Q9650 CPU and I'm experiencing stutter during Bink videos. The audio plays back fine, but the video appears to "lag" behind the audio at random times, only to quickly speed up to get back in sync. Any way to correct this? I assume it's something to do with the CPU but I'm not really sure where to start.
Reply 1 of 5, by DosFreak
Morrowind comes with bink 1.5a, you can try 1.5y
https://github.com/vogonsorg/radgametools/tree/main/binkw32
Lots of fixes since 1.5a
http://www.radgametools.com/bnkhist.htm
You can also try the last working build of OpenMW for Windows XP:
https://github.com/OpenMW/openmw/releases/tag/openmw-0.42.0
Also try upgrading your audio drivers.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 5, by DosFreak
Rename the old bink to something else
Rename the new bink to the same filename as the old one.
Reply 5 of 5, by DosFreak
Thanks!
https://github.com/vogonsorg/radgametools/wiki
