Need help identifying 386sx motherboard
First post, by hmmmmmmmmmmz
Hi all,
Bought a 386sx motherboard which seemed in a fairly acceptable state given the pictures of the seller.
Unfortunately upon arrival it's not, e.g. some of the socketed chips were reversed in their sockets, and I think they even got switched.
Also no jumpers and a microswitch box all in a "zero" state.
I browsed through all of stason.org to see if I could find the board and know how it should be configured (jumpers, switches).
Unfortunately no luck there, also a reverse image search didn't give the result I needed.
Please help identifying this fairly unique board:
- 1x 8-bit slot
- 5x 16-bit slots
- on board VGA (Chips & Technologies)
- on board I/O (C&T or NEC?)
- Has larger DIN for keyboard, but also ps/2
- 2x4 30-pin memory banks next to eachother
- i386sx CPU
Thanks for your help!
Reply 1 of 30, by imi
judging by the non-standard rear I/O and the alternative power connector this seems to be some brand specific motherboard, without knowing any more specifics it's gonna be hard to find though ^^
definitely a neat board though with the onboard I/O and VGA
on a unrelated note I'd recommend https://www.ultimateretro.net/en/ over sta*on as that site is riddled with ads and not as comfortable to use, unfortunately couldn't find it there either.
Reply 2 of 30, by hmmmmmmmmmmz
Thanks imi, I figured it would be some brand specific - hoped someone around here would be in for a challenge 😉
Dimensions are 330 x 330 mm.
It further reads PCS 3238 and then I guess revision D2 on the edge.
I'm not aware, nor could I find such brand 'PCS'.
The print doesn't state a year anywhere, though I would expect it to be late 80's or early 90's at most.
Reply 3 of 30, by imi
you could try dumping the BIOS and see if there's any info in there
olivetti had a range of computers called "PCS" but their boards look very different
Reply 4 of 30, by hmmmmmmmmmmz
The system does not boot, and I have no experience or tools to read such a chip.
I think the Intel P8942AH is the bios, as the other one is clearly the VGA bios.
Thanks for the Olivetti hint, I'll try to see what I can find adding that to my search queries.
Reply 5 of 30, by imi
that should be the keyboard controller, it seems to have both BIOS on one ROM, see how it lists VGA version and SYSTEM version seperately.
Reply 6 of 30, by weedeewee
hmmmmmmmmmmz wrote on 2022-06-04, 13:39:
... some of the socketed chips were reversed in their sockets, and I think they even got switched.
Which Chips exactly ?
Do not ask Why !
Reply 7 of 30, by hmmmmmmmmmmz
@imi I think you're right. I'm sorry, never had such a system before. Started out with an Olivetti 8086 as a kid, then briefly jumped to 486 and pentium.
If it's all working or clear what's wrong, then i'll manage. Maybe this is too hard of a challenge, since I don't even know what's wrong with the system.
Do you think a POST test card would work in such an old system?
@weedeewee both the bios chips were reversed in their sockets, with even some pins bent so they were out of the socket.
Where I was hoping to have bought a 'not tinkered with' motherboard that needed some cleaning and perhaps some easy to fix parts, as for example the oxidated crystal oscillator near the back plate.
Also all jumpers are missing, some led's or beeper that could indicate status would help.
Therefore I'm hoping to find a general layout and jumper settings.
I know this maybe sounds like crap, but old hardware is in my experience fairly robust. So I keep my hopes up!
Reply 8 of 30, by weedeewee
hmmmmmmmmmmz wrote on 2022-06-04, 19:01:
As stated before, one is the bios & vga bios chip, the other is the keyboard controller.
And from personal experience I can say that if the chip was reversed in the socket and the board has been powered on, the chip is now dead. (while the bent out of socket pins might offer a glimmer of hope)
Ergo,
You will need to find some compatible bios to program in a new chip.
as for jumpers, since this is not a standard AT, or baby AT board, any similarity to normal led or button connectors seems unlikely.
Identifying the board without the bios has just gotten a little bit more complicated.
I can only wish you Good luck and hope the internet archive gods will show you some mercy in this slightly frustrating task.
Do not ask Why !
Reply 9 of 30, by imi
are there markings underneath them? also are you sure they were reversed? measured ground pins?
and as weedeewee said, if you (or someone else for that matter) powered the board with the chips reversed they're most likely dead.
Reply 10 of 30, by hmmmmmmmmmmz
The ones that were 'out-of-socket' would be the Vpp and Vcc connectors from the socket point of view / G and A0 from the IC point of view for the VGA/System bios TMS27C210A.
For the Keyboard bios Intel P8042AH it was only the P21, so perhaps less luck here.
I did not power the board yet, but upon inspecting the board I noticed the pins out.
I carefully removed the chips from their sockets and noticed the notch on the chip did not match the notch on the socket.
A close look on the socketed chip in the top right corner (cache?) also has the notch not matching.
If anybody else has powered it, I don't know. The guy I purchased it from explained the board was in the same state as he recieved it, so also no luck there.
By now I'm afraid it's getting beyond my knowledge to repair, especially the fact that the chips are reversed.
Thanks for the good luck, sounds like I need it.
Reply 11 of 30, by weedeewee
If you've got a nice magnifying glass, you can take off the sticker off of the bios eprom. It likely has the UV window to erase it, looking through that you might be able to see damage.
Like is visible in this image.
Do not ask Why !
Reply 12 of 30, by hmmmmmmmmmmz
@weedeewee thank you for your help! Very clear on how to spot a defect.
I will definitely try that once I figure out how to restore the bios.
Still like to know the manufacturer and type of the mainboard, perhaps that would also help in restoring the bios if it's defective.
Reply 13 of 30, by imi
a notch on a socket isn't always conclusive, it should be, but I have been burned... or rather a whole set of cache chips because I relied on it, but it turned out that the sockets were installed the wrong way /o\ hence why measuring if it really is the correct way or not if you're unsure is helpful.
Reply 14 of 30, by weedeewee
you know, that unpopulated 3x4 psu connector, and those unpopulated connectors right around the cpu seem so familiar... frustratingly familiar since I don't recall where I saw those before.
Do not ask Why !
Reply 15 of 30, by imi
same ^^ could be a SUPU series B connector (that's the only name I found them under)
commodore used them on their older PCs but I think those were all 2x3 and I'm certain this isn't a commodore board either as those were pretty much always marked and it just doesn't look like one ^^
I have seen them on other computers before, but I also don't remember which ones.
edit: here's one for example: Re: Bought these (retro) hardware today
are there any markings on the backside of the board?
is the large DIN connector on the rear I/O actually a keyboard connector or does it have more pins?
a few more hires pictures of the board would be nice.
Reply 16 of 30, by hmmmmmmmmmmz
weedeewee wrote on 2022-06-04, 20:28:
If you've got a nice magnifying glass, you can take off the sticker off of the bios eprom. It likely has the UV window to erase […]
First of all a big thank you Imi and Weedewee for all of your help. In the meantime, I did the following:
Took off the sticker and had it under a microscope with LED illumination (as a precaution not to erase the contents) - all wires are intact. So far that's good luck right 😀
Also, I checked the ground signals according to the datasheets for both chips. Turns out they were reversed in their sockets and they were switched! What a mess!
Put both chips in, according to the matching ground signals. I also checked the power connector, ground signals match the AT PSU standard.
As I was now confident the BIOS'es were plugged in correctly, I put in some memory (70ns NEC 424800-70 / optional FastPage), keyboard, monitor and power and switched it on. Unfortunately, no luck.
No image is displayed, but also no 'smoke'.
The keyboard lights for num/caps/scroll go on and off - like normal. I don't know it that's an internal check of the keyboard or this is initiated by the keyboard BIOS?
For memory, I tested both banks with 4x
After ~ 15-20 seconds I switched it off again. None of the main chips felt unusual 'warm'.
Went the next step and took the memory (70ns Samsung KM44C1000AJ-7 / optional FastPage) and videocard (Trident 8900) from my only (working) 486 in put that in.
Unfortunately, again no screen appears. Put it back in the 486, and can confirm the tested parts are still working.
Clueless of my next step - given that I don't have the bios ROM nor the capabilities to load a new rom.
What would you guys do? I really like this system to be operational once more.
Will provide a picture of the backside and i/o panel later on.
The i/o panel has:
- 'keyboard' connector with 8 holes + gnd (on my 486 there are only 5 + gnd)
- VGA connector
- LPT connector
- ps/2 connector
On the backside it reads 3238-2 PCS / Made in Taiwan / Circuit side.
Furthermore it has markings KR / MVO 4791 and two stickers: sticker RI 35 WLT-0077-3 / sticker QC 13 WLT-0077-6
Reply 17 of 30, by imi
I had a hunch about that din connector ^^, looking at the board closely again I think this might be a video output as well
that might give some more clues as to the origin of this board.
a post card with speaker may help too
edit: oh look who else used that power connector ^^ http://ummr.altervista.org/ps270mb.htm
Reply 18 of 30, by hmmmmmmmmmmz
Thank you imi for your reply and effort in helping me.
Because I already powered it with a DIN AT keyboard plugged in, I checked the signals with the power connector and seem to match a keyboard plug.
- Pin 2 ('bottom right') is connected to ground
- Pin 4 ('bottom left') is connected to +5v
I believe it is a 2 layer print (top and bottom). Though wiring is fairly difficult to follow, I'm sure only 3 connections are on the top side and one (ground) on the bottom side connected to the keyboard connector.
This still is according to an DIN AT style keyboard requirements as far as I can tell.
Since I really enjoy this retro hobby (given some challenges) I will look for a POST card since it may come in handy either way.
Despite the fact that I wouldn't call myself a technician. I think I'm fairly OK in searching information and documentation which usually helps me out.
I really do think the board is 'OK' - it just all looks in overall good shape.
Worst part is on the 'Chips peripherals controller and Bt VSP' image. Some of the connecting lanes have dark spots. Also the back of the LPT port and the crystal in the op of that image has some corrosion.
Do you think this would cause the board not to function? What is your opinion on replacing the crystal? That's something I could try.
With help of your Olivetti hint I found this pocket service guide:
http://minuszerodegrees.net/manuals/Olivetti/ … h%20Edition.pdf
Browsed all the layouts and checked the parts list. Some parts match, but I guess the 'Chips & Technologies' combo was fairly common in those days. So still not sure it's an Olivetti.
(Neat I found the pocket service guide which also has the M240 which was my first IBM compatible as a kid when my dad stepped up to a 486).
Thanks again for helping me out and my apologies if my English is not that correct as it is not my native language.
Reply 19 of 30, by imi
where are you from if I may ask? or rather where did you get that board... might also help to look for local brands
