First post, by Sheriff Hobbes
Hi!
You all know the problem: You have a game installed and you figure out that it doesn't give you the option to reverse the mouse y-axis. Especially an FPS will make that unplayable for you. Just happened with Dark Rites. Default is mouse up for looking down, but I can only play vice versa.
Is there a mouse tool around which solves that problem?
Sheriff Hobbes
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
There's currently no way to change this besides messing with the sources.
Maybe somewhen the mouse movement/buttons will be included in the
mapper so they can be arbitrarily changed.
Reply 3 of 9, by ErikGG
I tried to add it to D.O.G by hooking into the Mouse LowLevel System Hook of Windows, and it worked as long as it wasn't DirectX or OpenGL that was rendering.
So the only two options I geuss there are left are rewriting a plugin dll for SDL or rewriting DosBox.
Read the new FAQ.doc
Reply 4 of 9, by Sheriff Hobbes
I think a good solution would only be inside DOSBox, because
a) portability - go with your game config to any computer and it will work
b) it's probably not so good tampering with your Windows drivers. It may work on a Windows XP, but not on Vista, etc.
If anybody of you DOSBox guys could do that, it'll be perfect. I'd like to help, but I'm not a programmer. 🙁
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 6 of 9, by tikbalang
here it is: ctmouse v2.1b4 including binaries with inverted axis.
    ctm21b4x.zip
    295.88 KiB
    2877 downloads
    ctmouse v2.1b4 with inverted axis.
ESS PCI DOS Drivers
_________________
Reply 8 of 9, by pycur
Sheriff Hobbes: I today found this game, and I also used ctmouseY.exe to invert the mouse axis in game, after that I hit Ctrl F5 to take some screens, and the game noticed me to changed mouse axis by itself without the tool...so F5 is simply changes axis in the game... 😁
Reply 9 of 9, by Kreshna Aryaguna Nurzaman
pycur wrote on 2019-08-09, 09:50:
Pardon the necro. Doesn't work for me. I thought the button F5 can toggle normal/inverted mouse axis as you described, but I press the button, and nothing happens. Once I load ctmouseY.exe, the Y axis stays inverted regardless.
Kreshna Aryaguna Nurzaman.
