First post, by biessea
Hi all folks,
After I revived an great old pearl like this IBM Pc, I just wanted to add a CD-ROM driver as it has the 5.25 bay free.
I can't make the system recognize it.
I have only one master hard disk, on the primary IDE, 270MB hard drive from Quantum.
I tried three different CD-ROM drives in the same IDE channel, as SLAVE.
No one of these is recognized.
I really don't know why, and I am asking if it is possibile to make it work.
Probably in the 1994 the cd-rom drives was rare and some systems can't accept at all? Chipset problem?
Someone can help me please.
Thanks a lot guys.
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 1 of 16, by rmay635703
I had this problem historically where a single channel IDE system would boot normally but the cd drivers could not find the drive during boot up.
Many older systems would not “see” a CD-ROM drive in the bios but this shouldn’t matter.
In some cases I had to change the physical setup of the cabling and even drive configurations
In others the only way I could get a cd to detect during boot was to use a sound card with a ide port.
I am uncertain what the reasons are.
Reply 2 of 16, by jakethompson1
Right, by "recognize" presumably you're talking about an ATAPI CD-ROM driver in config.sys, not the BIOS, correct? BIOSes did not have to care about CD-ROM drives' existence until El Torito booting was added.
Be aware that with a hard drive and ATAPI CD-ROM sharing the same IDE channel, you won't be able to use 32-bit disk access in Windows 3.1/WfW 3.11.
Reply 3 of 16, by appiah4
I've had a similar issue with my IBM PS/1, which is basically the same PC. It just refused to detect ATAPI drives as a Primary Slave in BIOS and if the BIOS did not detect them then the driver would not either. IIRC setting it up as a Primary Master worked, but then the HDD did not get detected. I had to go through quite a few optical drives until I eventually hooked up the optical drive through the IDE interface of a Sound Blaster 16 as Secondary Master. I will check on that PC this weekend and confirm.
jakethompson1 wrote on 2022-08-10, 14:34:
Not true for IBM PS/1 or Value/Point systems, these PCs have some hardware detection for CD-ROM and Sound Blaster built right into the BIOS.
Reply 4 of 16, by biessea
No, I was talking about recognize the drive in the bios and then in DOS too the driver that I try to load in config.sys doesn't recognize the drive.
Love beer, too.
Reply 5 of 16, by biessea
appiah4 wrote on 2022-08-10, 14:37:
Perfect, thanks a lot I wait for your check so, and I am happy that I found an user with my same system basically.
It is strange anyway, I have a secondary Ide channel too, but I haven't tried that way.
Do you think I can use the hard disk as primary master and then the cd-rom as secondary master?
Or it is better to use only one channel and use master/slave configuration?
Love beer, too.
Reply 6 of 16, by waterbeesje
For the CD ROM I always set them to secondary channel, master. That way the CD ROM is not dependent and does not have to share bandwidth with the HDD. File transfer will be a little faster.
As for the hard disk, could it be there is a setting for master with slave, matter without ata drive, slave and single drive?
Stuck at 10MHz...
Reply 7 of 16, by biessea
waterbeesje wrote on 2022-08-10, 16:57:
Thanks for the reply.
This hard disk, a Quantum one, has three little jumpers to shunt.
"The LPS 270 has four drive mode jumper options; DS, SP, CS and PO. To configure the drive as:
The MASTER of a two drive configuration or as the only drive: Jumper DS only, SP, CS and PO open.
A SLAVE drive in a two drive configuration: Remove any jumpers across DS, SP, CS or PO.
A MASTER drive in a two drive configuration if the SLAVE drive does not use DASP: Jumper DS and SP only.
CS not used, DO NOT install a jumper across this position.
PO not used, DO NOT install a jumper across this position."
Which one should I shunt if I want to use only one channel and then only one IDE cable? (less trash)
Love beer, too.
Reply 8 of 16, by rasz_pl
use it
master/slave IDE was a kludge/ post hoc hack
https://www.os2museum.com/wp/the-dual-drive-ide-hell/
AFAIR master drive must have explicit support for slave drive in order for the whole thing to work reliably.
Reply 9 of 16, by biessea
"When the drive is configured as a Master - that is, with the DS
jumper installed - the SP jumper should be installed on the Master
drive only if the Slave drive does not use the Drive Active/Slave
(DASP-) signal to indicate its presence."
Probably on the master drive (the quantum) I have to set TWO jumpers for what I am understanding, the DS and the SP (slave present) and in the cd-rom only shunt the slave jumper? This is a try worth of attention I think. I am now at work but when I'll return home I will try this.
I prefer to use only one channel cause I don't want too much cables inside the case.
Love beer, too.
Reply 10 of 16, by biessea
rasz_pl wrote on 2022-08-10, 17:30:
> I have a secondary Ide channel too, […]
use it
Ok, I've done it.
What a mess with two cables IDE inside a little case like that.
But all works now, my secondary IDE master CD-ROM drive is been recognized by vide-cdd.sys driver and correctly loaded in DOS 6.2.
Thanks at all, for all that replies, at the end I did it.
Love beer, too.
Reply 11 of 16, by waterbeesje
Great job, I'm sure you'll have loaded of fun with it!
Stuck at 10MHz...
Reply 12 of 16, by biessea
Oh yes, thank you!!!
I put some photos about that system are rocking right now!!!
Love beer, too.
Reply 13 of 16, by appiah4
Out of curiosity did that PC come with a Sound Blaster 16? And if it did, which exact model?
Reply 14 of 16, by biessea
appiah4 wrote on 2022-08-12, 08:46:
No, I dind't found a Sb16 only a Lan card inside.
Love beer, too.
Reply 15 of 16, by appiah4
biessea wrote on 2022-08-15, 12:59:
Thanks. I'm trying to figure out which exact model the Multimedia versions of the PS/1 and Value/Point came with. There is conflicting information regarding this, so trying to figure out..
Reply 16 of 16, by biessea
appiah4 wrote on 2022-08-15, 13:01:
You're welcome.
Love beer, too.
