Reply 1220 of 2154, by chrismeyer6
Chadti99 wrote on 2022-08-22, 02:17:What are you guys using for storage on the m919 boards? Recently acquired a 3.4 B/F version and it refuses to boot with my IDE to SD adapter. Although it’s able to detect the drive size in the bios.
In my experience SD to IDE adapters are an absolute crapshoot if they will work properly. I've had the best luck with CF to IDE adapters since they both use the same protocols and are electrical compatible.
