DOSBox ECE (for Windows & Linux)
Reply 1501 of 1508, by Giuliano
Hi everyone,
I was using DOSBox ECE r4447, and upgraded it today to r4481. I've noticed that the line below was removed from the dosbox-ece.conf file:
gusrate = 44100
I am supposing that it was also removed from the SVN version.
What was the reason behind this removal?
Does it mean that the gusrate value is now fixed at 44100? Or: does it mean that the gusrate value is now equal to the mixer's rate value?
Cheers.
Reply 1502 of 1508, by realnc
Giuliano wrote on 2022-09-17, 14:07:
I was using DOSBox ECE r4447, and upgraded it today to r4481. I've noticed that the line below was removed from the dosbox-ece.c […]
gusrate = 44100
I believe the GUS uses a rate that depends on the amount of the currently used channels. Apparently, dosbox now emulates this properly and thus there's no "gusrate" option anymore. The rate matches what the real hardware would use, and then it gets resampled to the mixer rate.
Reply 1503 of 1508, by jmarsh
It was removed because performing upsampling in the GUS code (rather than the mixer) blended samples that should have been left out of the output entirely. Typically this caused samples from opposite channels to be blended together, ruining stereo separation.
Reply 1504 of 1508, by videogamer555
Yesterplay80 wrote on 2017-02-08, 07:35:
Please post all questions concerning DOSBox ECE in this thread for now on, so we can keep other threads tidy and on topic!
I compiled a build of DOSBox ECE for Linux. Consider it highly experimental, since I only run Linux in a VM, I can't test all the features, because the VM is lacking hardware acceleration. So it would be very nice if someone could run some tests with it. It comes (or should come) with all the features of the Windows build, minus the possibility to select the midi device by name or a part of it. Please download it (link is in my signature), play with it and let me know if something's not working or missing!
What is ECE?
Reply 1505 of 1508, by morphinejh
videogamer555 wrote on 2022-10-18, 08:23:
What is ECE?
It stands for Enhanced Community Edition.
More details here:
https://yesterplay.net/dosboxece/
(it does look to be down at the moment though)
Update: Expired certificate at the moment.
Reply 1506 of 1508, by Falcosoft
morphinejh wrote on 2022-10-19, 13:50:
.... More details here: https://yesterplay.net/dosboxece/ […]
More details here:
It's not down per se but it has a certificate error:
154.14 KiB
To be honest I never understood the Google forced https everywhere movement. Why should a simple download site that does not require any user login/data be available only through https and redirect any http connection attempts to non-working https? (It uses HTTP Strict Transport Security policy.)
So you should try an alternative browser that still enables you to add an exception even in case of non-working certificates and HTTP Strict Transport Security (HSTS) sites.
Website, Facebook, Youtube
Falcosoft Midi Player + Munt VSTi + BassMidi VSTi topic
Reply 1507 of 1508, by morphinejh
Falcosoft wrote on 2022-10-19, 14:05:
Good point, I updated above. I don't use Chrome directly, but rather one of its Chromium variants. I can advance through it manually, but didn't want to post that as instructions per se.
Reply 1508 of 1508, by Dr. Rabbit
Any idea why I can't seem to get reverb working with the integrated fluidsynth? Changing the fluid.reverb.roomsize, fluid.reverb.damping , fluid.reverb.width or fluid.reverb.level variables in dosbox-ECE.conf even to extreme numbers doesnt do anything. Reverb is enabled, of course, with fluid.reverb being "yes". I'm currently using this SC-55 soundfont.
Not a real doctor.
