Nexxen wrote on 2022-10-06, 12:42:Could you provide a list of tests you perform? (I suppose Phil's + others?)
I'd like to give it a go this weekend. I don't have […]
I'd like to give it a go this weekend. I don't have much time, but if I don't have to look for myself, following a list, I'd try "bot-like" (brain dead 😀).
Thanks a lot to Jan for his help.
Edit:
What are the settings I should enter in BIOS to make it as fast as possible?
Hi there...,
Yes some of the collection of Phil´s dosbench 1.4, but also some real working test.
my BIOS setting are tested by following test`s
- CPU identification Utility v1.25
- cache chk 4
- System Speed Test v4.78
- Superscape 3D Bench 1.0
- Chrisbench 320 & 640
- Topbench 0.38a
- Doom Demo at Full Details
- PC Player
.....also testet
- Windows 3.11 connecting via LAN to NAS Drive, copy files from NAS and from drives to drives
- playing audio on Windows 3.11
- playing DOOM2 at MS-DOS v1.66 at a minimium of 30 Minutes
- several cold and warmboots
so now i offer the Setting for an AMD DX4-120 with 8 kByte L1-cache and WriteBack for the BIOS Patch J.2 for AWARD-BIOS m912
please notice ! the settings are depending on the Hardware with is not common for some people! it depends of which cache chips and which RAM chips you use and will not work for all other common RAM Modules and Cache Chips, notice this could be the fact if the setting might not work on your M912 !
Hardware for the following BIOS Settings are:
- only one bank of RAM installed, in PS/2 Socket, the Module is about 64 MByte with parity and 60ns. This modules are hard to find !
- cache with a total amount of 1024 kbyte L2 Cache with 15ns, don´t use 20 or 25 chips. chips model number is "IS61C1024-15N"
- also use tag chip with 15ns !
- no other VLB Cards except only one Graphic Card
now first the motherboard setting that are also important:
-JP16 = ON (Vesa Clock over 33)
-JP17 = OFF (Vesa Wait State = 0)
BIOS Setting now:
BIOS FEATURES SETUP......
- CPU Internal Cache = Enabled
- External Cache = Enabled
- Memory Parity Check = Enabled
CHIPSET FEATURES SETUP......
- Auto Configuration = Disabled
- DRAM Wait State select = 1 WS
- DRAM Page Mode = Fast
- L2 Cache Read Wait State = 3-2-2-2
- L2 Cache Write Wait State = 0 WS
- L1 Cache Update Scheme = Wr-Back
- Video BIOS Cacheable = OFF (might work ON on some other cards)
- ISA Bus Clock Option = CLKI/4
- Local Ready Delay Setting = Delay 1T
- Alt Bit in Tag SRAM = 7+1 Bits
get very fine result in System Speed, all working stable under stress testet over some days.
If you get no L1 Cache or no L2 Cache or no Write Back Mode, it could depending on your selected Hardware RAM and cache, that this settings are to agressive. In Future i will do some more test with 133@160, but this require more better Hardware on Cache and/or RAM Modules.
So i hope i could help you.
regards Hendrik
