First post, by MrSteelrose
Mobo: GA-6BX7 Gigabyte
RAM: 384Mb Sdram pc133 running at 100
CPU: Pentium 3 Coppermine at 700mhz
GPU: Geforce ti 4200 with nvidia_9x_81.98 drivers
Scores in 3dmarks 99: 5140
Scores in 3dmarks 2000: 4137 in both 3dmarks 99 and 2000 i get the same score in 800x600 and 1024x768 and 16 bit and 32 bit colors makes no difference either
In unreal with patch 226 i run direct 3d at get something like 10-30 FPS maybe average 22 or something, when running that demo with the castle at the start. i think it is because of bad direct 3d support
Carmageddon TDR 2000, tried playing for a bit my FPS was around 20-50 average 30 maybe, with 1024x768 high graphic settings. Game is from the year 2000
its interesting that resolution only affects performance in unreal but not in Carmageddon TDR 2000 and 3dmarks 99/2000
Pentium MMX 200mhz. ati 3d rage2c + voodoo 1 64 MB SDRAM
Pentium 2 300mhz geforce 2 gts + voodoo2 SLI 256 MB SDRAM
pentium 3 933 mhz voodoo3 3ooo AGP. 256 MB SDRAM
Pentium 4 2.8ghz geforce 4TI 4200
Intel 3770 geforce 780
Intel 10700k Geforce RTX 3080
Reply 1 of 33, by Repo Man11
You should use the 45.23 driver for better results. For comparison, I just tested a Tyan S1854 with a P3 Coppermine 1000, PC133 512 megabytes and a Quadro 700 (Ti 4400 equivalent) ; after using Rivatuner to overclock the card and to force AGP 4X, my best 3D 2001 score was around 6,700.
Reply 2 of 33, by atom1kk
On a P3 coppermine 800 and a Geforce 2 TI I get in standard settings in 3D Mark 2000 6150 points. so something seems to be wrong
Reply 3 of 33, by MrSteelrose
tried the Omge 1.45.23 (performance settings) drivers got a 15% points increase in 3d marks 2000,
still not enough. must be something more that is wrong, gonna check out drivers for mobo next
Reply 5 of 33, by MrSteelrose
no, Windows 98SE
Reply 6 of 33, by Ozzuneoj
I feel like there's some kind of issue with AGP. Maybe AGP\chipset driver, AGP speed, Fastwrites, aperture size, etc.
Make sure it isn't running in PCI compatibility mode or something crazy like that (can't remember where exactly to check that).
Reply 7 of 33, by Repo Man11
Installing Rivatuner is a quick and easy way to view all of the graphics card settings.
Reply 8 of 33, by bloodem
The problem is definitely the 81.98 driver.
In my experience, the BEST Win98 driver for a GeForce 4 Ti 4200 (if it's the AGP 4X version!) is 30.82.
45.23 is also OK, but it's slower than 30.82 (particularly when used on slower platforms).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 9 of 33, by MrSteelrose
what score should i expect if/when i get this machine to work properly? 7000 points in 3dmarks2000?
Reply 10 of 33, by MrSteelrose
i tried using Riva Tuner but it refuses to let me enable fast write to AGP
Reply 11 of 33, by Warlord
is dma enabled for hdd?
Reply 12 of 33, by MrSteelrose
DMA is enabled yes, i was thinking is this because i use Windows 98 SE? i have another computer for XP so thats not a solution i want
Reply 13 of 33, by bloodem
Again: you are using subpar video drivers.
See the attached screenshots with the 3DMark2000 and 3DMark99 results for the following configuration:
- MSI MS-6163 ver. 2 (Intel 440BX chipset)
- Pentium 3 Coppermine 700 MHz (FSB 100)
- GeForce 2 GTS (driver version 7.76)
With a GeForce 4 Ti 4200 AGP 4X + driver version 30.82 (and the same system configuration) I would expect ~ 6000 points in 3DMark2000.
If your GeForce 4 Ti 4200 is the AGP 8X version, then driver version 30.82 won't work, and you will need to go with 4x.xx drivers.
Reply 14 of 33, by bloodem
So... I dug out a GeForce 4 Ti 4400 AGP 4X, here are the results with driver 30.82 on the same system as the one above.
Just in case anyone is curious about the CPU scaling, I also overclocked the CPU to 933 MHz (FSB133) and ran 3DMark99 / 2000 again.
Obviously, the results with the Ti 4200 should be the same, since these tests are HEAVILY CPU limited.
Reply 15 of 33, by atom1kk
6000 with a Ti 4400? I mean i get 6150 with a gf2 ti. The card should be alot faster
Reply 16 of 33, by bloodem
atom1kk wrote on 2022-11-23, 18:45:
The fact that the Ti 4400 is much faster is irrelevant when hitting CPU bottlenecks.
Both the GeForce 2 GTS and the GeForce 4 Ti 4400 are bottlenecked by the Coppermine.
If I were to remove the CPU bottleneck and test them on a very fast Core 2 Duo CPU, the GeForce 2 GTS would scale up to ~ 12000 points in 3DMark 2000, while the GeForce 4 Ti 4400 would scale up to ~ 21000 points.
So... at ~6000 points, we are far from extracting all the performance that both of these cards are capable of.
So, getting back to your question, when a CPU bottleneck is involved, the card with the most efficient/lightweight drivers will "win" by a few hundred points. And it just so happens that the 7.76 drivers that I'm using with the GeForce 2 are a bit faster with slower CPUs and A LOT faster with very slow CPUs (AMD K6-2).
Now, if I were to test 3DMark2000 at 1600 x 1200 x 32, results would be a lot different. At that point the GeForce 2 GTS would become the bottleneck, so we'd see a big difference between it and the GeForce 4 Ti.
Reply 17 of 33, by MrSteelrose
Now with the 30.82 drivers i get 5030 points in 3dmarks2000
81.91 drivers i tried with first got me 4137
with 45.23 drivers i got something like 4500.
i got 900 points in total in increase. its still 1000 lower than what i should get compared with others with the same components.
It seems that fast write for agp is not possible on my motherboard neither is agp 4x so im stuck with with 2x Agp speed. Maybe lacking these options is the reason why im falling short in my scores.
or maybe it is because im stuck at 100 bus speed. i tried going for 133 bus speed but the computer freezes when booting to windows, i know i succeded setting the DIP switches correctly since POST says: pentium III 933 Mhz
Reply 18 of 33, by Kruton 9000
I think Pentium 3 700 MHz is simply too slow for this video card. You need something faster to get good performance with it. In Russian Chip journal review from 2002 journalists used Athlon XP 2000+ and DDR memory when testing GeForce 4 series. They achieved 5800 points on MX440 and 10000 points on 4400Ti in 3DMark 2001SE (1024x768@32bit).
P.S. They used Windows XP + 27.50 driver version
Reply 19 of 33, by MrSteelrose
i did three things.
1 overclocked system speed from 100 to 133 and thereby going from 700 to 933 Mhz
2 increased voltage by 10%
3 i changed timing on my SDRAM from CL2 to CL3 because they are labeled as 3.
now i got 6750 points. this is performance i can live with, but im still curious why i wont reach your scores of 8091. is the difference between 4200 and 4400 that big? or is it because you can run in 4x AGP speed?
