My mobo is ready to for some sxl2 overclocking!
Just got the AnyClk device installed! Pretty nifty little device! First test was at 40mhz on a AMD 386dx-40 (soldered on one) next was at 50mhz cpu /100mhz crystal clock. So far stable! More mhz to come!
Edit: tried 5.33x multi. No dice. (106.7fsb) so my max mhz on this cpu lies somewhere between 100 and 106.7 crystal clock.
I have the crystals to find out exactly where, in steps that are actually often less than 1mhz at a time. 😮
So when I get the sxl2 I’m really gonna know what its max clock is for sure 🤣.
I haven’t messed with isa clock ratio. Might try that next. Could be the limiting factor. Also I have some purple ram coming 4mb x 8 (32mb) so this system should be flying soon! :p pic doesn’t show it, but I ordered parity ram.
