Reply 680 of 1395, by feipoa
I thought I would drive in the issue with clearance around the socket a little more. This is just on the same motherboard, I have one near miss that would get hit with a tantalum on the bottom, and another direct hit. You can see a jumper directly hitting the PCB. If that jumper is under the VRM section, it will hit any component. So I think it is a good idea not to even leave solder pads for a bottom cap as a jumper will short on it.
The attachment Clearances_1.JPG is no longer available
The attachment Clearances_2.JPG is no longer available
Reply 681 of 1395, by feipoa
Sphere478 wrote on 2022-12-07, 03:03:
Some of us make ramen in the coffee pot man. […]
feipoa wrote on 2022-12-07, 02:39:
Hmmm... did I say that somewhere? If so, can you point me to the typo and I can edit it. So far, there was no net average impro […]
Sphere478 wrote on 2022-12-07, 02:10:
So it sounds like waveform gets better the more decoupling is added all the way to 21?
Hmmm... did I say that somewhere? If so, can you point me to the typo and I can edit it. So far, there was no net average improvement of 21 caps over 10. I am going to take it down to 8 and check again. EDIT: ahhh, only slightly better on a per-pin basis, but not as an average. EDIT2: if you want even better per-pin, wait for the results and discussion.
Anything I am missing? Anything else? :-)
I like what rasz_pl did with the decoupling caps. If not possible, forget about it.
I have a few more days of testing.
Yesturday's photos coming soon...
Sorry man, there is a lot of info in this thread and a lot of posts I’m tryin to keep up, doin a thousand things here.
If I forget or mis quote just remind me :-)
I’m searching posts for what rasz_pl did with decoupling caps. I forgot what they did? Do you mean with the flat on one side round on other pads? I know that will cause issues on some of the locations, but let me see if it could work for 8 locations?🤔
I see where he wanted me to pull back the 5v plane. Might work, but I feel iffy about pulling from so few pins. I also see more possible problems from that and no real benefit. What if mobo didn’t route those well?
Gonna try and make a better marking for pin one like requested
Pulling copper away from decoupling cap/socket pins may be less of an issue than square pads. But also has issues of reducing cross section.
I’ll stand by for your updates and conclusions.
If you are going to try it with 8 pins, I recommend these for location and a symmetric look.
The attachment 8_caps_location.JPG is no longer available
The attachment cap pads.png is no longer available
Reply 682 of 1395, by Sphere478
Okay, lemme look at those locations 😀
The attachment image.jpg is no longer available
This might be doable in a few spots.
This size and shape can be used without hurting the cross section in a number of places.
The round holes and oval pads of the regulator are messing up the clearance over rides. I believe I already solved this problem though. So I’m going to just leave it. The other option is to change the global clearance of that flood. 🤔 which I think is unwarranted at this time as I think I have already solved the problem.
Sphere's PCB projects.
Reply 684 of 1395, by feipoa
Sphere478 wrote on 2022-12-07, 04:06:
These are pretty even and unobstructed. Approve?
Yeah, if that's what worked out conveniently. Are you able to make the pad the size rasz showed in my above image?
Reply 685 of 1395, by feipoa
The image you provided is looking at GND and OUT, but the issue I'm having is IN and GND. See high-res image here:
See how the two triangles make an hourglass with the 5V plane (2nd pin from left)? Are you able to get this side of the 5V plane further away from GND (middle pin)?
The attachment VRM_GND_problem_zone_1.JPG is no longer available
The attachment VRM_GND_problem_zone_2.JPG is no longer available
Reply 686 of 1395, by Sphere478
Able, yes. But about half the locations would cut into cross section. I think the pad size I put in is gonna work. Remember we are soldering to the pin not the board.
Btw, hey rasz_pl.
How did you make that shape? Two overlapping pads? That’s what I did. It generates a drc and a overlap into the hole on 3d viewer 🤣. Is there a better way?
Reply 687 of 1395, by Sphere478
feipoa wrote on 2022-12-07, 04:39:
The image you provided is looking at GND and OUT, but the issue I'm having is IN and GND. See high-res image here: […]
😀 also, silk there. All fixed! ..?
Reply 689 of 1395, by Sphere478
🤔 lookin good.
Figured out how to improve the cin and cout vias to a ridiculous amount. And took the time to make a custom flood for them.
Thoughts?
I think this should really be nice.
I’m sure there will be a few more tweaks over the next few days. But are there any concerns I didn’t address?
Reply 691 of 1395, by feipoa
Were you able to make the 8 solder pads like this? I cannot tell from the photos you provided, but looks like you are content with solder mask? Doing it like shown below will reduce goof ups during assembly.
Normally on these adaptors, I see a big white triangle to identify pin 1. Inserting 386/486 incorrectly is a very common problem, so might want to consider:
The attachment triangle.jpeg is no longer available
The attachment triangle2.jpeg is no longer available
On the bottom, I'd be a little more direct and write something like:
for PGA-168 SXL/SXL2 CPUs only
Without the only, one may think, 'ok, works with SXL chips, but maybe works with others too. Let's try... F'
Reply 692 of 1395, by Sphere478
Didn’t do as close together, but yes I did do that. See the green outlines screen grab for shape of pads now download/file.php?id=151998&mode=view
I marked pin one better, but you REALLY wanted it marked haha. How’s this? 😀
Reply 693 of 1395, by feipoa
Sphere478 wrote on 2022-12-07, 06:44:
I marked pin one better, but you REALLY wanted it marked haha. How’s this? :-)
Yes, the world will thank you for that white triangle. It will likely save a CPU or two in the years to come.
I've finished up my testing. I ran the scale at 100 mV this time and did at least a dozen perturbations. Will present later, some changes needed to PCB to make the MIC perform better, closer to the LP. Broader spectrum of VRMs supported, I think the better, especially will all these recent 'out of stock' component listings on mouser/digikey.
Reply 694 of 1395, by Sphere478
Yeah, availability of regulators is one of the primary reasons I decided to just go external power supply on my socket 5/7/ss7 voltage interposer tweaker. Also with target voltages between 0.3 and 1.3v lower than available supply voltage it seemed iffy to try and regulate from available on board supply, so external power source was needed anyway. May as well be a in line power adapter. Aslo linear isn’t a good option after socket 3 really. So complexity was higher and different for each option if one went nla Socket 5/7 technically has two vcc5 pins but I believe many later boards didn’r route them. So powering from that was out Also only two pins for vcc5 is sus. Sorry tangent 🤣
Anyway. Yea, you should give some thought to future proofing this. I can make a special version with terminal pads for external power pretty easily. Just replace the regulator and remove the trimmer and resistor traces/pad And include it in release as a alternate for future retro goers
Reply 695 of 1395, by galanopu
Coming soon... This was the request of someone who donated to me.
Results within the next few days. The rest in a video and then to the store.
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migronelectronics.bigcartel.com
Reply 696 of 1395, by Sphere478
Ooo a nice side by side design! 😀
The attachment 72638A11-75BF-472B-9442-EF7976ECC60F.jpeg is no longer available
Hey Feiopa, whatcha think of using these?
Reply 697 of 1395, by rasz_pl
feipoa wrote on 2022-12-07, 03:34:
Removing those 4 tantalums from the centre region, which were 22 uF, 470 nF, 150 nF, 220 nF:
Noise on Vcc5 mostly disappears, or down to 48 mV and the noise on Vcc3 remains about the same.
fascinating, so they just acted like antenna?
Sphere478 wrote on 2022-12-07, 03:57:
moar, pull more copper away
click on pad, E, overrides, enter 0.4, B to refill
The attachment point4 clearance.jpg is no longer available
Sphere478 wrote on 2022-12-07, 04:41:
hey rasz_pl.
The attachment custom pad.jpg is no longer available
+ manual 0.4 clearance
whats with all the silk screen over the solder pads?
Reply 698 of 1395, by Sphere478
Okay, I’ll look some more later 😀
Silk is clearanced in gerbers when kicad generates them.
The silk is extra protection against these shorting problems.
I think it makes the decoupling caps look cool also. 😀
Reply 699 of 1395, by rasz_pl
sphere 2 CPUInterposer386-486.zip:
- can cut away 1mm on three sides (left right and bottom) and still fit memw
- can even cut upper edge 1mm. pull vrmsense track lower in middle layer under J1 footprint, same for NIO and SO tracks, dont route them on the edge.
- moooaaarr clearance
- clearance is better than silkscreen
