First post, by flightjunkie
Oh boy. This went worse than I expected. So, in my first proper windows 98 SE build, I am faced with a string of issues with sound and individual games(all of which are DOS, as windows games run fine so far)
My specs are as follows
Motherboard-QDI advanced 10t
CPU-Pentium III 1000mhz
GPU-3dfx VooDoo3 2000
Soundcard-SoundBlaster Live! 5.1 CT4830 PCI+Vibra16 ISA
Hard disk-WD800 80gb
RAM-TwinMOS 256MB
OS-Windows 98 SE
The sound driver was downloaded from Vogons drivers here: http://www.vogonsdrivers.com/getfile.php?fileid=804
First issue is that windows sounds work, but I got no sound in games and no sound in videos. For example, if I get a game that has some promotional videos from other games on the disc, the video's got no sound. Sole exception to this rule(but only just) is Nuclear strike, who's music works during gameplay. And that's basically it with this. Originally I intended to used an SB0220, but I've read somewhere that it had issues with the VIA chipset of the motherboard I use. I also tried to make the onboard sound to work but no dice there either. Maybe I did something wrong with the drivers, I am not really sure.
So now we move on to the games, Individually
DESCENT II
The first game I tried running. It seems to have speed issues. At the highest resolution it goes in slooooooooow moooootioooooooon, while in the lowest itmovesreallyfreakingfast, and I am not really sure, but it might have something to do with the Voodoo3. In regards with the sound, I did not try to recreate it, but I think, right after I started messing with the sound testing and automatic hardware detection, windows seem to started crapping out, with UI elements stop working after I tried to use them.
NASCAR RACING
Man, it's been a while since I last installed a game through floppies, but I digress. Now, Nascar Racing, runs fine, but there is a single issue. When in setup you choose to test the sound the whole system crashes. I tried doing this both in win98 and in DOS mode, and the computer hanged both times.
JANE'S AH-64D LONGBOW
In the case of longbow I can't even run the game. When I try to do so, I get an error about not enough files and buffers and I have to increase them in Config.sys. Of course It doesn't tell me where Config.sys is
The next few games are from a collection called MEGAMEDIA MEGAPAK 4, and they are all on CDs
BLACK KNIGH MARINE STRIKE FIGHTER
When trying to install, I get an error that there is not enough space. Of course I wouldn't be mentioning this if there wasn't 69(😎) Gigabytes available on the hard drive. The game offers the option to run it directly from the disk. But I get an error for not setting up my sound. Of course when I try to do that I get an error that the driver could not be loaded or something like that(regardless of the soundcard I choose). Though strangely at starting up the setup utility I get a message that says that a "BLASTER" environment was detected. Even If I choose no sound the game still refuses to run giving me the same error. I don't know if you see a pattern forming here.
TORNADO OPERATION DESERT STORM
This game will straight up won't run. I get a message that there is not enough space, and that's the jist of it.
DAWN PATROL
Another game from this pack I failed to run. I have to choose some graphics card from an utility to run it, but no option seems to work.
Lastly here's a few issues I got with DOS
-The Disk drive is designated as D:, however when I try to switch to it, DOS tells me it's an invalid drive.
-How do I scroll in DOS?
-It happened once, but there was one time I tried exiting DOS, and it got stuck at restarting windows, and I'd like to prevent this from happening in the future
The Salvaged parts Rig that cost me nothing.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-TwinMOS 256MB of RAM
-Windows 98 SE
Reply 1 of 35, by flightjunkie
Damn! I guess It must be my luck. Got US navy fighters Gold today. It installed fine, but I can't run it. If I try to run it from windows I get a blank DOS screen with the blinking thing where you type, in the corner. If I try to run it through dos directly, it asks me for the CD.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 2 of 35, by chinny22
How are you booting into dos?
Boot disk, Shortcut on desktop, Restart in dos mode from Shutdown screen?
Reply 3 of 35, by flightjunkie
chinny22 wrote on 2023-01-23, 12:16:
From Shutdown screen.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 4 of 35, by chinny22
In this case you should have 2 files in c:\
autoexe.dos and config.dos.
Which are automaticity renamed autoexec.bat and config.sys when you reboot into dos mode.
If you copy the contents of both files here we can see what's been loaded and what may be missing.
Also I'm guessing D: drive is your CD-ROM? This will need drivers to work in dos
Dos does not support scrolling.
Win9x is alot more fragile then NT versions, blue screens were just one of those things back when these PC's were daily drivers. The occasional hang isn't anything to worry about.
Reply 5 of 35, by elszgensa
> My specs are in my signature.
Some people don't care for, and disable, signatures - so they don't see those specs. Also, you might later update your sig, which could make earlier questions referencing them nonsensical to read. Just include all important stuff in the post itself. Treat it as self contained.
Now, to not derail the thread further:
I'll assume you mean text mode, not a graphical one? There's no scrollback, but there's a couple ways to show text one screenful at a time. You can pipe stuff into the "more" command. Some commands also have parameters for pagination, like "dir /p".
Reply 6 of 35, by Gmlb256
Seems that the OP isn't familiar with DOS. "Restart in MS-DOS Mode" from the shutdown screen only executes the DOSSTART.BAT, located in C:\WINDOWS and doesn't run CONFIG.SYS nor AUTOEXEC.BAT.
For something friendlier to beginners, I recommend Phil's MS-DOS Mode Super Easy.
Lastly, get an ISA sound card as a companion for the best sound compatibility in MS-DOS mode. The motherboard mentioned in OP's signature (at the time of this writing, QDI Advance 10T) at least has one ISA slot.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 7 of 35, by flightjunkie
elszgensa wrote on 2023-01-23, 14:00:
> My specs are in my signature. […]
Yes, Fixed. I didn't know you could disable Sigs.
Gmlb256 wrote on 2023-01-23, 14:05:
I was considering an older soundcard as well, But I decided to go with the soundblaster live for now, and when the need arises, plug one. Thing is, until I resolve the current issue I am having with the Soundblaster live and make sure that it's not that, which is causing the issues, I will avoid it. Let's have one issue at a time.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 8 of 35, by chinny22
As I understand it dosstart.bat calls up the to .dos files in c:\ and renames them to the correct names while in your dos session. I did have to do a quick google on this as I've always done the desktop shortcut even back in the late 90's.
I didn't know about Phils pre configured one, I'd also recommend using that at least while getting the hang of how everything works
Reply 9 of 35, by Gmlb256
chinny22 wrote on 2023-01-23, 15:33:
In my experience, when executing a PIF shortcut that starts MS-DOS mode with custom CONFIG.SYS and AUTOEXEC.BAT settings, the extension of the original ones gets renamed to .WOS during the session.
IIRC, the .DOS files only appears if an older standalone version of MS-DOS was installed prior and in Windows 95, there is an option to start the previous version if the main partition isn't FAT32.
Reply 10 of 35, by flightjunkie
I downoloaded Phil's solution. There is just a couple of issues. For starters on C there is no "drivers" folder. Am I supposed to create it, or is it supposed to exist already? Secondly, Videccd.sys doesn't show up in windows 98 se👻. Like I used my primary PC to both put it in a USB stick and burn on a CD, but it just won't show up. Any ideas?
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 11 of 35, by Gmlb256
flightjunkie wrote on 2023-01-23, 17:07:
If you read the entire information on the site I linked, you will see the following about the supplied drivers.zip which has both VIDECDD.SYS and CTMOUSE.EXE (CuteMouse).
Extract into C:\DRIVERS. This is for the optical drive (CD or DVD) and mouse
The DRIVERS folder should be indeed created in the root of the C: drive.
Reply 12 of 35, by flightjunkie
Gmlb256 wrote on 2023-01-23, 17:15:
If you read the entire information on the site I linked, you will see the following about the supplied drivers.zip which has bot […]
Uhhh I think I need to rephrase that. I got the file. I can see Videccd.sys on my primary PC. But when I try to transfer it on my retro rig it does not show up in the USB stick or the CD I burned it on.
BTW a heads up I tried running the age of empires games (1 and 2) Both seem to have sound in movies, but not in game. I Also tried to re install the SB live driver to no effect.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 13 of 35, by Gmlb256
flightjunkie wrote on 2023-01-23, 17:47:
.SYS files are hidden by default in Windows 9x, go to "Folder Options" and there is a section mentioning "Hidden Files" in the "View" tab, from there either select "Do not show hidden files" or "Show all files".
I forgot to mention that important detail 😜, my apologies.
The WDM driver that you downloaded aren't reliable. Try the following one instead which includes both WDM and VxD drivers: http://www.vogonsdrivers.com/getfile.php?fileid=512
Phil also has a guide explaining how to make sure that the VxD driver for the SBLive! is installed: https://www.youtube.com/watch?v=z-HiLp5p820&t=300s
Reply 14 of 35, by flightjunkie
So I got good news, bad news, and I got worse news.
Good news is that thanks to Phil's solution, I got both CD and mouse working in dos. After that I tried running games directly through dos. US navy fighters run without a hitch, and same goes with Longbow which gave me no files and buffers error message. I'd prefer to run them from windows, but still.
The bad news are that 1) The Black knight and Tornado still complained about limited hard disk space and that is trying different dos options. Running Blark knight straight from the disk still yielded the same issues with sound, and 2) The different sound blaster driver did not work. I had the same results. wanted to try and install the VxD on its own, but then the worst happened.
And the worst is that after I uninstalled the old SB driver, It started to throw BSoD at restart. When I tried to boot to DOS, it would stay on windows and I would need to manually reboot. Eventually after a session on dos, when I attempted to restart windows it would not. After another restart, the computer stopped seeing the hard drive at all.
It might be a clear cut case of a faulty hard drive giving up the ghost, but I will have to stick another HDD in there just to make sure. After that I was considering either getting another ide HDD(I know a guy who sells and he has them tested), an IDE adapter for a sata HDD, or an IDE SD or flash card adapter with a card. Still makes me wonder if there is any correlation with other issues(especially the sound one).
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 15 of 35, by elszgensa
About the free drive space issues - Try a smaller drive, or at least making a smaller partition. 80 gigs is way larger that games from that time ever had reason to expect to deal with, so their free space check routines may handle them incorrectly (and, for example, overflow).
Reply 16 of 35, by jheronimus
flightjunkie wrote on 2023-01-22, 09:58:
DESCENT II
Descent II is just speed sensitive, nothing to do with the Voodoo card. It can become too fast even on fast Socket 7 chips. I think, it mostly affects some animations though, not the gameplay (like the ship wobbling up and down really fast when you're not moving). In late 90s people were already using source ports for that (D1X and D2X).
MR BIOS catalog
Unicore catalog
Reply 17 of 35, by Gmlb256
jheronimus wrote on 2023-01-24, 16:38:
DESCENT II
A workaround is available for the 3dfx version of Descent II (both the original and D2_3dfx) by simply setting the following environment variable prior: SET FX_GLIDE_SWAPINTERVAL=2
It caps the frame rate to the half of the screen refresh rate. Example: 30 FPS if 60 Hz is set.
Reply 18 of 35, by flightjunkie
elszgensa wrote on 2023-01-24, 12:45:
What would be an optimal size to allocate? And aren't there any workarounds?
Anyway, UPDATE TIME!
good news! Computer started recognizing the hard drive again. What I did was to remove the battery, disconnect the hard drive and drain the computer of all power, and then run it, shut it down and reconnect everything again. Now it seems to run remarkably well, but I am not sure if it will ever happen again, or if it was an HDD issue or a motherboard issue. Maybe it was something I did on the bios. Anyhow, Another great thing is that sound now seemingly works. I tried Phil's suggestion of directly installing the driver and it seems it worked in windows games.
On the DOS front, I still can't boot USNF and Longbow through windows. And though Longbow has sound this time, I can't get USNF to have sound. See, If I want SB16 emulation to initialize, I need to start DOS with expanded memory. However In that mode, USNF will cause a reboot whenever I try to enter the hardware setup menu. I am positive that should I manage to access the hardware setup, and set up the sound, It will very likely work.
BTW I think I might install that ISA sound card when I am done with the issues. So, I got a SoundBlaster 15, an AWE32 and a SoundBlaster pro 2.0, ESS audiodrive, Vibra 16 and ALS120. I am a bit doubtful about the 16 and awe32, because although they look fine, I literally found them in the garbage.
P.S: I need to find patches for Jane's longbow as it has a very annoying bug with the sound, among other things. I could only find 1.04f but it won't install as it is asking 1.03f to be installed before.(might get gold at some point, but the original is the one I had. That's why I went with it).
EDIT: I got another update. This time with Descent II. I got sound working on that one. Strange enough I could only get sound to work on DOS, since If I tried anything on windows, DOS would crap itself and I would have to close it.
-QDI advanced 10t
-3dfx VooDoo3 2000
-WD800 80gb HDD
-Windows 98 SE
Reply 19 of 35, by chinny22
I'd actually install the ISA card now.
The SB Pro or Vibra is probably the easiest starter card as creative is the defacto card of this era.
Unlike the Live dos drivers, ISA cards don't need memory managers running so that should sort your USNF issue. Plus the cards resources (IRQ, DMA) should remain the same in both dos and windows.
I suspect the Live is been given one set of resources in pure dos and another in windows which is why games don't work in both.
