Reply 20 of 32, by Marco
Hi, thanks.
- It is only a Two-ended Cable (1 Connector to Adapter, Other remaining to the HDD. And the HDD is terminated)
- I just enabled SCAMP and Plug&Play ID'ing and the error now went away.
So it should be ok 😀
Anyway I will get a "standard" 4-connector cable including terminator. I will test this as well while deactivating HDD onboard termination.
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5428 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 21 of 32, by Marco
My performance results so far:
Procom Disk Bench Random Xfer Rate:
IDE160GB@8GB HDD: 2749kb/s
SCSI HDD: 2247kb/s
Sisoft Sandra Drive Index:
IDE160GB@8GB HDD: 1548
SCSI HDD: 1444
Real World Copy 100 Files:
IDE-to-IDE: 1:13
SCSI-to-SCSI: 1:19
Real World copy 100 Files MSDOS w/o cache:
IDE: 0:36
SCSI: 0:57
Time-till-Winword-starts-while-copy-100-files:
IDE: 45sec
SCSI: 39sec
Copy 100 files while Turbo95 bench running:
IDE: 38sec
SCSI: 32sec
Attention: Especially the real world Win95 benchmarks are hard to trust, since on the 386SX running multi-tasked applications (1x app + 1x copyjob) is not reliable. As e.g. the app is put on hold / hanging or something.
Questions:
1. Do you have any idea to better bench further? Apps like WInbench etc. wont work as they mostly require something more on my pure basic Win95 setup
2. Are the results suprising to you?
Reply 22 of 32, by Disruptor
Ah, well, I even can burn CDs with 2x on my 386SX/20 SCSI.
On a faster 386SX (40 MHz + cache) I'd try 4x too, since I was not far away from that border.
Reply 23 of 32, by Marco
Ok so get a stable and continious 300Kb/s burst rate including keeping buffers filled.
Thats ok I would say. But not quite sure if I'd say thats amazing. Ahhhh sorry. 😀
Reply 24 of 32, by Disruptor
It's a 386SX beneath the pain of a not so well designed 32 bit operating system.
Reply 25 of 32, by Marco
One thing is here definitely my ISA/DMA Bus Speed. If I lower that to normal I drop down to below 2mb/s for diskbench whereby scsi performance remains.
Interesting but in my „overclock“ setup the IDE performance with faster IDE HDD seem to be just the better option. And I don’t even talk about noise 😀 the IDE just uses 12MHz whereby SCSI sticks at 5,7MHz and won’t go higher. No one could really explain why that is btw (to me) 😀
PS: anyway it still can be that interacting in windows while doing file transfers feels faster. But It can simply be imagination.
Reply 26 of 32, by Disruptor
Did you try the DOS copy test with or without loaded ASPI driver?
Reply 27 of 32, by Marco
Always with aspi4dos.
Pls also remind that access time of the 160gb ide might be (much?) better. And its internal cache is larger.
Pls also don’t compare dos copy with windows copy as the set of files was different
Update:
Just want to inform all that I also tested with:
- the new scsi cable: same results
- shadowed scsi rom: same results
- ensuring sync neg and fast scsi: was done already
- disabling scsi parity: same results.
Reply 28 of 32, by Sphere478
How many ns do you get in speedsys?
2mb/sec seems
About right. These aren’t going to be speed demons. Seek time is where you can pick up some performance maybe. I get 8ns on my 140gb drive.
This might be about as fast as you can get on isa. Don’t forget. You are doing this without loading the cpu much. So don’t undercut your success here. 😀
Sphere's PCB projects.
Reply 29 of 32, by Marco
Benches added here
Faster HDD= IDE
Slower HDD= SCSI. Seems all limited at 3mb/s
Reply 30 of 32, by maxtherabbit
The "DMA transfer speed" setting on the 154x series cards makes all the difference. Try setting it higher if you can, but you must test to make sure it doesn't crash or corrupt data
Reply 31 of 32, by Marco
Sure thanks. Already tried out. Cannot go higher than 5,7! All self Test fail and real-time boot as well. Ideas on how to make it possible?
Reply 32 of 32, by maxtherabbit
Marco wrote on 2023-01-26, 22:21:
Short of "use a different motherboard" not really
5.7 is pretty poor, seems like 154x cards and that motherboard are just a poor match
